For sale:1987 Series 4 FC RX7 jap import body 138,000k
It has the following mods:
Engine: large Extend ported and doweled 13bt engine rebuilt 12,700kms ago by MRE, with brand new series 6 housings series 4 rotors with series 6 springs side,corner seals etc and PTS 2mm unbreakable seals. S6 upper inlet manifold modified to fit a s5 lower inlet manifold with large ported runners. Twin belt alt pulley. motor sport clutch with 1200kg presser plate. PWR 40mm aluminum radiator, with 16" Davis Craig thermo fan, massive 300x300x45 oil cooler.
Fuel: NipponDenso intake 750hp fuel pump, 880cc primary injectors and 1700cc secondary injectors.
Intake: the response is crazy with this Full Trust TD06 20g turbo kit with external gate and screamer pipe greddy manifold, KnN long nose filter, 450x300x76 front mount intercooler with custom built stainless steal piping, turbosmart v port bov.
Exhaust: custom built 3" turbo back system going to one massive resonator to twin rotaflow mufflers with long stainless steel 4" tips.
Electronics: WOLF3d v4.57plus ecu with hand controller, HKS turbo timer, Autometer boost,oil temp, oil presser gauge, Cheetah alarm and immobilizer, OPTIMA dry cell battery behind passenger seat with kill switch, pioneer CD ipod/usb player.
Exterior: Origin body kit, aero mirrors, colour white with black bonnet and pop up lights, s5 custom LED tail lights only two in Australia as i know of not in pic will be showing new pics soon.
Interior:Do-luck floor brace, rear seats removed. Recaro leather bucket seats, deep dish sports steering wheel, short shifter kit.
Diff: series 5 gearbox, s6 torsen LSD, reinforced diff mount bracket.
Brakes: EBC turbo grove rotors "slotted and dimpled", EBC green stuff pads, braided brake,oil,turbo lines.
Suspension; Rear koni yellow damper adjustable shocks with RSR springs, front tein HA coilovers with cusco camber tops, height damper and camber adjustable. Whiteline adjustable front and rear sway bars, polyurethane superpro bushes, DTSS rear stear eliminator bushes, rose jointed adjustable tie rod ends, aluminum subframe spacers front strut brase.
Wheels: 18"x9.5 rear and 18"x8.5 front deep dish wheels.
Item Condition:Mechanically perfect, clean interior with no missing parts or cracks, body kit has some cracks and chips underneath, Excellent condition
Price and price conditions:$17,000. Now $16,000 negotiable!! or swap for FD plus cash your way.
Extra Info:Comes with many spares and original parts to be returned to stock condition. The car makes 249RWKW @ 11psi and produces 786Nm of torque, dyno sheet available. safe as tune. All receipts and service history available. Live in Adelaide and regod
Pictures: http://www.nissansilvia.com/forums/inde ... pic=387417
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
