Hi Guys,
Just wondering if any one is aware of a decent body kit supplier who sells quality kits. I've looked at a number of websites and even ebay and i've come up with full kits for around the $600 mark.
Have kits really come down this much within the last couple of years or is it the quality... I would have expected to pay a minimum of around $1000 for an R33 kit... a mate paid $1200 for an R32 kit so im just curious...
any help would be greatly appreciated
https://www.sau.com.au/forums/topic/277772-decent-body-kit-supplier/
R33 kits aren't exactly rare seeing as how it's the most common skyline ... so if I were you, I'd just keep a close eye on the for sale section and get a genuine/plastic kit .. quality will always be better than any fibreglass copies and not much more expensive either.
cheers thanks for your help guys
You can definately pick up kits for $600 from places but they dont always fit properly and can need alot more work...geuine kits like Trust/Do-Luck etc...cost more but are better quality unless they are cheap replicas
There are various reasons for bodykits varying in price from the cheap to the uber expensive. First of all, price is NEVER a good indicator of the quality.
The manufacturing costs of bodykits vary depending on the location, the material used, location of manufacture and the marketing spin. As with any big Japanese brands you will pay for the name along with paying for the part. So don't fall into the trap that just because it has a label that a) its a genuine item and b) that it will fit like a glove. I have worked with both and have been surprised by both on numerous occasions.
You also have to remember that the cars a lot of these kits are going on are at least 5-10 years old. With age comes tolerance differences from general driving and minor accidents ("but my car has never been in a crash", I hear you say. A few questions for you. Have you owned the car from new? Do you think someone buys a brand new sports car and drives it only to church on Sundays? Do you think all repairs are visible? etc.)
Also material chose is one to be careful of too. Although fibreglass cannot absorb the amount of shock plastic (polyurethane) can, it is easy to repair and customise if required.
I would bank on pretty much ANY bodykit needing some massaging to get a good fit, as every car is different and will have a slightly different fit.
Do your research and find a reputable company that you have confidence with and will take the time to go through your concerns.
Yes we do sell bodykits, however this information is merely a guide for those looking. We understand there are many and varied reasons on who you will chose to buy a kit from, however as we are keen car nuts ourselves we want to equip everyone with the knowledge to make a good decision so that making your car look the way you want it an enjoyable time not a painful experience.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
