Looking for cams for this engine setup. Preferably HKS's. Here in the US, it's impossible to find ANYTHING for the RB series. Are all RB series cams the same (critical dimensions, not lift/duration)? What I'm asking is, are cams for a RB20 head compatible with a 25 head? What about cams for a 26 head? Also, does the VCT affect anything as far as compatibility? I hope I'm not confusing you all too much, I'm new to the RB series. Also, if you could suggest shops that I could get these parts through, or even just part numbers to cams that will work (pref. HKS). Thanks
-InterC00l
Hi, might be able to help with a couple of things,
HKS step one cams are compatible with NVCS, and will bolt straight up without any mods to the heads.
I am having fitted 256/8.8mm in and 264/9.0mm exh (both step one), which appears to be a good combo for the street and track, also will be fitting an adj exh cam gear to dial it in.
If you want to retain the NVCS, you cannot fit an adjustable cam gear to the inlet side.
HKS cams can be bought through www.greenline.jp at quite reasonable prices, but the us has HKS dealers, cant they order them in for you?
Sorry about part numbers, my cam boxes are in the workshop as my cams are being fitted and I am at home. I will try to remeber to get them next time I am down there.
RB26 cams are not compatible with NVCS also they are solid lifter, RB25 is hydraulic.
RB20 cams - I know nothing:).
Hi Intercool, Steve covered most of it. RB20's are the same as RB25's except they don't have VVT. So you can use GTR cams in RB20's. Keep the lift under 9 mm and you won't have any trouble with using solid cams with the hydraulic lifters.
Our preferred camshafts for RB25DET are Tomei Poncams, they work very well with the VVT. There are accurately timed so we have found no advantage from using an adjustable camshaft pulley on the exhaust camshaft.
Hope that helps
What about a solid lifter conversion? I believe Tomei makes one. Also, is it just the R32 RB25DE head that does not have VCT, or do all naturally aspirated RB25 heads lack VCT. I would rather run without the VCT.
As far as getting these in the US, I have people that can, but finding documentation on such items is dificult.
-InterC00l
RB25DE from R32 does not have NVCS, from R33 it does.
If you want solid lifters and no NVCS, why not just use an RB26 head on your 3L bottom end. Probably easier and cheaper, plus you get the nice 6 throttle body plenum.
RB cams/NVCS specs are here: http://www.tomei-p.co.jp/_2003web-catalogu...haft-specs.html
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
