Hi Guys,
Sale time. Items located in Rockhampton but can ship.
1. Customised vented stocko bonnet. Perfect fitment guaranteed as its a STOCK nissan bonnet, its steel and should save alot of trouble with the police aswell. $700ono
2. Genuine Nismo Carbon Pillar Garnishes - Used for 4 months, perfect condition. They need new double sided badge tape from super cheap to be used, as ripping them off left half of it on my pillars lol. Expensive new, in genuine box to prove. $120
3. R34 Din slot - self explanitory. $20
4. R34 GTT spoiler, KR4 sonic silver, genuine. $150
5. Genuine nissan floor mats for R34 - Pic coming. Pretty good nick. Slight stain on one back one that you dont really see, and a small wear mark on drivers side. $100
6. VPW dual pillar mount for R34 - brand new condition. Used double sided badge tape to hold, therefore no drill holes or anything. Replacement cost 200 bucks. Gauges not included in sale. $120
7. R34 GTT 17 inch rims with tires - two pretty good, others still just legal. Some gutter rash on one rim. easy fix. $400
Pics below of most things.
Thanks for looking! Pick up some good gear for your R34 :) Might find some more stuff soon too.
PM, reply in thead or text 0420943163
Edited by Granthem
https://www.sau.com.au/forums/topic/277788-r34-goodies/
Ah ok. Well you have the option of only attaching it with Double sided tape.
Thats what I did.
Honestly, to remove this, took 1 minute flat.
If you got defected, you could clear if very easily.
Mind you, in QLD i got pulled up many times, even by DOT, and never once got defected :D
Yeh you could only really fit one before going above the wheel.
https://www.sau.com.au/forums/topic/277788-r34-goodies/#findComment-4707458
  • 3 weeks later...
Hi mate, I have absolutely no idea to be honest.
I would assume they would be fairly similar, at least close enough to still fit.
I know of a few 4 door 34s in town but sadly dont know them well enough to ask them for a trial fit.
New pics of spoiler coming soon - and by the looks of things my next car will not be a skyline if things go to plan. So feel free to make an offer and it will be considered. These things must moooooooove people!
https://www.sau.com.au/forums/topic/277788-r34-goodies/#findComment-4746916
***also for sale***
Neo engine cover - brackets for it are there aswell. I hit it with some white and red paint when i got bored lol. 50 bucks
Stock air box with panel filter - looks rather clean from memory - 80 bucks
https://www.sau.com.au/forums/topic/277788-r34-goodies/#findComment-4746958
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
