Hi guys,
Can anyone recommend a good car electrician that knows the V35 in Sydney?
My odometer started to click over very slowly and the Fuel gauge does not move past half way!
tried the tests outlined in the service manual and the entire instrument panel works fine all gauges move (except for the fuel)
i filled up the car till fuel spitted out and the fuel gauge moved from nearly empty till half way only.
The odometer clicks over very slowly as 100 mt every 400m or so.
When i checked the Fuel leave to see what type of consumption i got it just showed *.* /km
Any ideas or help is appreciated.
Cristian
https://www.sau.com.au/forums/topic/277789-good-electrician-in-sydney/
I have my M35 booked in tomorrow with a Auto Electrician who does work for North Shore Prestige. He has a scan gauge that will read the M35/V35 and most other cars.
I can let you know tomorrow afternoon what sort of job he does as he is tracking down an obscure electrical problem on my car.
He is based in Cromer, Northern Beaches.
Cheers
Andy
Cheers
Andy
That would be great Andy!!
Cristian
Cristian
Hi Cristian
The Auto Electrician is,
All Car Auto Electrics (Greg) 9971 0900
Unit 11/1-5 Thew Parade, Cromer.
He has all the equipment to read the M35/V35's and is very good with his work.
I spoke to Greg about his knowledge of the V35 and he said he has worked on a few but did not describe himself as an expert on the car.
He is very competent and helpful.
I guess it is a matter of is there a better, closer or more convienient option.
Cheers
Andy
Let me know if you dont get anywhere Cristian, you are welcome to use my data cable to investigate fault codes?
Tim,
Where abouts are you located? I'm new to the V35 so i guess i'll need some help with the codes...
Hi Cristian
Cheers
Andy
Thanks Andy, i'll see how i go with this...
Im down in Hurstville way, so if you wanna check em out, we'd have to do it soon.
My car is still in pieces while my license is suspended until next Thursday, at which point my OBDII cable is getting fitted behind the dash and i dont plan to unplug it any time soon hahaha
So if you have no luck with the techo dude up in North, perhaps you could swing by and i can run the cable through to your car and test. You got till next Thursday. 16th.
Tim,
There is no way i can get to the electrician up in cromer anytime soon so i might take you up on the offer. Will let you know soonish.
Thanks
Tim,
Thanks
Tim,
I guess i missed out , been flat chat at work.
Anyone else has any ideas about this issue/ refferals for a electrician in sydney?
To answer the other question this has been happening since Mid June
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
