Hi all, i have had a change in heart and wish to sell these items. Both are brand new in box and cost me A LOT more than what i a selling it for.
Trust Oil Pump Brand new in box includes a new genuine nissan oil seal and genuine nissan gasket. $1550 delivered
Copied these details,
It is commonly known that the stock oil pump on the RB26 engines will starve tuned engines of oil at high RPM's. When running an engine with so much time and money spent, why risk the inevitable with a stock pump? With the Greddy High Flow Oil Pump, the flow capacity will increase by 23-30% at any RPM range when compared to the stock pump. Trust guarantees high strength due to the SCM435 chrome molybdenum steel material used for the gearing. To get the most from your set-up, Trust recommends the use of their high capacity oil pan in conjunction with the High Flow Oil Pump. This pump is good for 12000rpm
l/min at 800 RPM : 5.5 (4.4 stock)
l/min at 2000 RPM : 19.7 (15.2 stock)
l/min at 6000 RPM : 59.0 (46.7 stock)
Trust Clear Timing Belt Cover $115 delivered.
Dont have pics sorry. but brand new in box.
parts are in brisbane.
Edited by AtomicBomberMan
its pretty dirty if its new, why is there black on the pump if its new?
Im sure Chris will clarify, but I would think its just the angle of the photo, and probably the excess oil film that covers the pump when it comes sealed from Greddy reflecting off the black backing plate, thus making it look dirty.
yes thats right. thanks nick. the back plate on the pump is black, and not black from oil. the oil on the back plate and over the pump is from factory. its to stop the gears inside rusting. it is not engine oil. Pump is brand new and never fitted. it still has the plastic covering the oil holes.
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
    • As above, replace as many as you can afford. If anything, due to old age.
    • Can confirm previous shop that built my motor had no fking clue about oil control and caused my motor to shit itself after two track days. Current shop, Birrong Automotive, has managed to build me a motor, not to mention, has also let me tune it myself and it has yet to blow up after 7 track days. Great oiling success, yashimash.
