Hey guys, clearing out a few r33 spares. Items located in sydney, but I can post everything except the sunroof
R33 ECU (manual) - $100
R33 Sunroof setup, roof lining, control unit, wiring - $200, pickup only
R33 Front LCAs - $100/pair
R33 Castor rods, near new bushes - $80/pair
R33 Gts-t manual tailshaft - $120
RB flywheel - $75
Catco 3" hiflow cat, suits R32 and R33, near new - $100
R33 GTR 27mm rear Swaybar, great upgrade for Gts-t - $100
R33 Power Steering rack - $120
R33 S1 Steering wheel - $100
R33 Gts-t Power Sterring pump - $100
R33 S2 Aircon Condenser - $120
R33 Breather pipe (from bov -> intake) - $25
R33 Rubber intake pipe - $25
R33 GTR front Strut brace - $100
Also have:
R33 Aircon compressor - $100
R33 Stock side-mount intercooler piping - $40
R33 Gts-t manual diff - $200, pickup only
R33 Boot interior - $80, pickup only
Cheers!
https://www.sau.com.au/forums/topic/277860-r33-parts/
Willing to separate the boot interior?? Only after the part that covers the battery.
Cheers
Sorry mate I want to keep it together
Is the ecu s1 or s2?
Thanks
Hiya, it's from a series 2
https://www.sau.com.au/forums/topic/277860-r33-parts/#findComment-4697660
hi mate ill take the sunroof pm me your number to organise something
Pm sent
hi, i wanna the struct bar, and where can i pick it up?
Is it for your gts-t? It will only fit GTR/rb26 unfortunately
https://www.sau.com.au/forums/topic/277860-r33-parts/#findComment-4700785
  • 3 weeks later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
