I'd get them painted. You'll get a nice clean unmarked surface again. Only thing is you'd have to spray the rest accordingly.
I don't even know how previous owners could do some things they do to the interior. A car I checked out last year had a horendous interior - like someone had thrown some corrosive acid all over the dash.
+ I have a sticky bit like in the 2nd pic you've got. Would this be from some sort of adhesive used to hold attach a gauge pod or something?
Edited by peterw
Nothing, the cars been sitting in the sun with double sided tape, some effort and some goo remover may work but the best option is to paint the whole dash peice, check out the DIY section.
You can also do the door trims the same way.
You can remove residual adhesive with Double D Eucalyptus Oil or Kero or Tar/Bug Remover.
That last pic looks like damage by someone with long fingernails or someone trying to get out of the car in a damn hurry from red/blue flashing lights?
Mm thanks guys. I'll probably up painting the lot black as per factory.
Its just weird cause the rest of the interior is perfect, the steering wheel is basically new :|
Anyway of getting rid of the stuff in the 2nd pic? Don't have the $ to cut it out and put a screen in there....
K&N wax and grease remover available from most autobarn,super cheap etc stores will take care of the glue residue from double sided tape no problem.
the last few pics are where the latex coating on the dash and plastic trim around the window switches have been worn/scratched off and will need repainting.
heres the link for headunit removal.
http://www.skylinesaustralia.com/forums/He...al-t190825.html
Edited by Jack88
You'll need to use eucalyptus oil or something similar (as above) , but check what it does to the dash materiel in a hidden away spot first before you rub the shit out of the dash.(2nd pic) If your lucky it will all come off without effecting surface too much, then go over it with some dash cleaner (armorol)
In the 4th pic down that latex coating here is fkd, so with that whole dash fascia you can gently rub all the latex coating all off (very sore fingers) and hope the plastic under it is good enough to be polished back to a nice shine. (did this on mine, not 100% but good enough until i decide to paint it) But more than likely it will need to be painted. If you paint it just sand the latex off first. Or just buy a dash fascia off ebay. good luck
a citrus goo remover will be ok for those white marks in ur first pic, duno about the rest. definetly get the trim near the door painted, will make it look 10times better. someone went to war with that thing lol prolly previous owner parked in the same spot everyday and the sun just killed it. go to wreckers and see if u can even get a new part. goodluck bud
if you wanted to make the passenger part of the dash look a bit better, you can go see autobarn and they sell dashmats to suit R33's. they probably wont have stock, but they get them from Command Auto Group. I have one on my silvia in black. looks good IMO.
Eucalyptus oil will work, but you may see that after the tape is removed that under the sticker will be a slightly different colour to the rest of the dash.
maybe just replace the fascia and the plastic part ont he door. even just take them off a 25t. i cant see them costing that much!?
2nd pic - definately Eucalyptus oil and then armourall the dash.
Eucalyptus oil didn't work... For the 2nd pic, it just made the dash a different colour around it and didn't really take anything off after hard scrubbing.. When I tried to get the white circle, the clear around it vanished but still left most of the white... :)
Plan B/C.
Do you think that "T-Cut Polish" in 'black' can be used? Show your car to your local car parts store to confirm.
It's used to blend surrounding colours to the basic 'black' if you get it in 'black'.
Black shoe polish on some hidden 'test' area can be Plan C/D
Ok use "Goo remover" (supermarket laundry asile) for the sticky shit.
As for the door trim, remove & take paint off with nail polish remover sand back with super fine paper & respray- I just did
my door trims & centre console they came up a treat! Two days work in total-F*ck paying someone esle to do it I paid
$24 for some pressure packs in colour & clear matt (autobarn/supercheap).
Get into it :)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
