Hey guys,
My landlord is considering to install a reverse cycle refrigerated air conditioner throughout the house and I was wondering if anyone has suggestions on where to go or which brands they would recommend? The house is roughly 2500sqm so it would need a decent sized motor to cool the house down. The budget given was around the 6k mark.. is this budget realistic? Any help would be deeply appreciated!
Cheers,
Bernard
Greets man.
Try Jarrahdale Heating and Cooling in Maddington.
The owner Leon hooked me up about 6 months back and I was very happy with the price and service.
Will check on it! Thanks mate!
Thanks everyone for your input! Sigh.. unfortunately.. I guess that's the budget that the landlord gave me.. i can try to squeeze a bit more for a decent unit instead of getting a crappy unit...
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
    • Thanks Duncan, I don't have a GTR these days mate. Gone soft..
    • Yeah. air pressure leakdown test is where I would be headed next here, using one's ears to determine whether it's the valves or bores/rings leaking...
    • More likely you didn't bed the rings in correctly and have glazed the bores. Running with misfires on a fresh build is somewhat of a no-no. Surely no-one "smoke tests" the combustion chamber? That's what a leakdown test is for. Smoke testing is, um, a bit of a wank at best, and only really useful for external pipework.
    • Well, obviously that kit is not a relocation kit or anything other than just the original isolators and the like. I would suggest that it should be a matter of just bending up some flat bar to build a mount over the top of some other diff, with the flat bar held to the back of the diff by the rear hat bolts. A little welding, a little thinking about how to secure the front of this structure, maybe some different hoses in case you can't get it in just the right place.
