  • Replies 140
Posted Images
thats the only part that concerns me.
I doubt car crushing will be dished out like an on-the-spot fine. There would have to be a scrutineering process to go thru ... IF it ever happens.
Does that mean each Police Cruiser will be fitted with a car crusher?
Exactly. :)
Edited by RubyRS4
its very concerning that any officer has the right to get your pride and joy crushed
i highly doubt that this will pass but for those being stupid there should be something apart from crushing their car.....like suspension of license for 2 years or greater something like that as the driver is the one that needs to learn the lesson not the car lol......a car doesnt drive by itself its the tool behind it.....and if this law passes and you get a little bit of wheel spin of the line....can be classified as a hoon and car crushed....dont think we want that happening do we
"These repeat offenders are hell bent on driving dangerously and engaging in anti-social behavior," Mr Rann said.
how is it anti social?
and if it goes ahead, they better have some strict guidelines for the crushing of the cars. I mean it would be too easy for any police officer to go well thats an import and deserves to be crushed, even tho you havent done anything wrong?
if that makes sense
trouble with license suspension is alot of tools ignore it and get away with it. id like to see tuffer penalties for the repeat offenders, ive talked to knobs who just kept driving as normal without a license and there extra suspensions hardly seem to fit the crime.
the talk of car crushing is leaving me picturing the ending of gone in 60seconds :) "unicorn"
i guess that will make these cars rarer and therefore more valuable, as apposed to the defect the crap outa em till they sell it cheap so someone that caresless about it can drive it.
Edited by Inline 6
comment submitted. *waits for it to be edited to support the crushing of cars and then posted*
this state shits me to tears. seriously. rann, the big thinker has attempted to introduce or has introduced such awesome and helpful laws as;
ZERO tolerance on speeding. (ie, 1km/h and you get a fine, it was kicked out first time round, notice the 'creeper' ad's on these days? yeah? hes trying again)
anti association. (sure, it works on criminals in theory, but what about when he gets bored? or someone takes his ear and suggests another group to target? a bad idea if there ever was one.)
car crushing. (waste of time, waste of money, waste of resources, i could go on. and the system their basing it on, well, in the states they do crush cars, yes, but rarely if theyre privately owned unless youve really f**ked up, they tend to only crush rebirthed cars)
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
