I havent looked at the price of Supra's for over 3 years. When i bought my R32 they were all worth 40k plus, and that would have been a crappy auto
1993 Toyota Supra Twin Turbo
6 Speed, Sports exhaust system, TRD side skirts and rear pods, 18 inch mag wheels, HKS Air filter, Alarm, Stereo, Custom graphics, Tinted windows, 75,000kms
Registered and ready to go
Only $25,990
Damn, i didnt realse they were that cheap. At that sort of money, why are there so many R33s on the road, if i had $25-30,000 to go shopping with i think a Supra looks pretty attractive at that money.
https://www.sau.com.au/forums/topic/27790-does-this-price-sound-right/
Fair call about the brakes, but the series 1 brakes still arent exactly bad, are they?...its just that the update models brakes are much better.
Apparently they weigh approx 1450kg and have a lazy 208kw (174rwkws with only an exhaust and std boost). They use alloy susp components with factory Bilsteins, so when you say they dont handle...have you driven one, or are you just assuming due to the weight?
Ill have to take your word as to how good they are at the track as i have only seen a bloke in a std auto...
I wish i had enough money and garage space for about 5 cars.:(
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
