Technically, if its plumbed back yes, its legal.
But its still loud, i wouldn't open it up past a cop, im sure they will have a say in it.
BTW, take out the fins in the end of your ssq bov. This will get rid of that homosexual squeek sound.
Edited by r33cruiser
  • Replies 47
dude there messing with you
the flutter although it sounds great it actualy doing damage to you turbo!!!.
if you have your bov spring too loose it doeasnt vent properly so the air is forced back through your turbo (the wrong way ) to the
doooo dooo do do dod do do noise you hear is the blades of your turbo cutting through the air .
as for bov increasing power im no expert but if that were true it would be stated in the sticky about skyline power mods .
baaaaaaaaaaahahahaha, in think someone needs to learn about sarcasm.
also needs to learn about how a bov works. if the spring is too loose on a bov then it will vent properly. it just might leak a bit under acceleration. if a spring is too tight then it won't vent properly and you will get compressor surge.
there are too many posts in this thread and not enough time to facepalm them all. threads like this are why i spend most of my time in wasteland. at least discussions there are intelligent.... or contain pics of hot bishes
you could have totally just plus oned this here post...so rude :happy:
ok so i am just about to convert my stock plenum to a forward facing plazmaman...
now i guess i have to remove the stock rb25 bov as there is no place to put it now..
how would i set up a bov on a forward facing setup?
i have a turbosmart vport bov laying around i could use but i would rather use stock and it doesnt have the ghey sound...
any ideas?
not for a street car..
making 300rwkw..
Sorry its not a great photo but this is how mines setup. Lots of people say it needs to be as close to your throttle body as possible but mine works fine as it is, Little tight but still vents etc.
A friend has his on the pipe off the front of his TB with a stainless pipe across the front of the car (just behind the radiator into his intake pipe) but its a bit cheaper to do it the way mine is done
Edited by 89CAL
personally the stock BOV and a good pod sounds great. take the heat shield off the bonnet or get a frp bonnet, for more noise.
not a fan of flutter (wen i hear it i look around for the nearest VL with chrome on it).
ssv, greddy type-r/s etc meh.
but each to their own.
any ideas?
making 300rwkw..
Weld it on in the driver side gaurd, before the t/b. VTA it. 300kw, im guessing tuned? Any decent tuner can tune in a vta bov.
Easiest option, i did it...but of course there is always the risk of being pulled up for it.
I cbf making up a return pipe, they look like ass, chrome or no chrome.
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
