I live in Bangor man, if i see a black r34 matching that description i will pm you
Thanks mate, I've been all over looking in every carpark and scrapyard i can find, tried down Kembla Grange, Greenacre, Hurstville, Menai etc
My black R34 was roaming around from Earlwood > Kirrawee > Beverly Hills > Mortdale > Earlwood on Saturday, and no-one spotted me!
Then again, no-one took my car either T.G.
Oh well, I'm looking for 2 cars now. Someone on PA lost their car around there too (on Friday)!
A s15 Silvia white stolen from engadine on wednesday night about 1km from where R34 was stolen
details here
http://www.nissansilvia.com/forums/index.p...howtopic=395485
Looks like someone has a shopping list and hitting the engadine area
unfortunately I'd expect a few more to go before the end of the month.
I doub't we'll ever see those cars again.
Stolen from Out the front of my house in Yarrawarrah NSW (Near Engadine).
Smashed window and gone.
Completely unmodified car I can't believe why anyone would want it, other than just young hoons.
Has nissan factory aero bodykit, 2 door coupe stock rear wing Black nismo carbon pillar garnishes and eyelids.
Number plate black on white XLR 85U.
If anyone has seen this car aywhere please contact police immediately.
Please help I'm devestated.
Damn thats terrible. I had 2 abo kids ruin my drivers door lock with a screw driver trying to get into my Er34 sedan. Some of us have the worse luck
hey man maybe you should post up the vin and engine number too incase they try selling it off without the plates or something.
might make it a bit easier to find ??
Edited by 32NSMO
details here
dammit, i'm at the gf's over the weekends in menai, car stays down there on the street every week, ive done so for the last year and a half ive had my car, nothing so far but i'm still paranoid about someone taking it even though its alarmed, immobilised, club locked religiously. plus comprehensive insurance, but i just dont want anyone to wreck it or take it coz of the work ive put into it so far....
i feel for your loss but really as its been said on this forum a million times, if you cant afford to put comprehensive insurance on a skyline, go for something cheaper, not worth not having comp insurance as you and others have figured out.
Hope it still comes back to you in one piece and hope financially you can recover if the worst case plays out
I'll keep a look out down my way also
down near parra area,
I have nightmares about my car being stolen, wake up sweating !!!
went crazy at my gf once cus i thought i lost it in the car park, its a horrible feeling
good luck mate ill look out for ya
Saved ur number into my phone
if i see even the plates on a different R34 ill buzz ya
  • 5 months later...
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
