  • Replies 417
Entry List
1 Ryan Bell Sileighty
2 Michael Eichorn Sileighty
3 Mat Cross Corona
4 Tim Williamson R32GTST
5 Russell Cunningham R32GTST
6 Roman Plotnikov 180sx
7 Vince Ritchie R32GTST
8 Dane Stokes Sti
9 Luke Schulze R33GTST
10 Juliette Remfrey Pulsar
11 Ryan Campbell R32GTST
12 Kieran Robinson Supra
13 Leon Stapley R33GTST
14 Mohammed Tebeleh 180sx
15 John Richardson R33GTST
16 Che Boocock R33GTST
17 Adrian mueller WRX
18 Antony Ivancic Mystery
19 Terence Ho R33GTST
20 Gerald Tan Supra
21 Phillip Mak S13
22 Mario West EVO7
23 Shane Janssen R33GTR
24 Chris Stacey R33GTR
25 Brendan Pryor R33GTST
26 Daniel Hall R34GTT
27 Chris Mccolan EVO7
28 David Talbot S13
29 Karlos Broulidakis VN Commodore
30 Daniel Garber 180sx
31 Patrick Antoskiewicz R32GTST
32 Cassie Cruickshank WRX
33 Steven Trajkovski R32GTST
Relax Dave, your on the list, now get your car finished!
Side note, Mat has put up a thread for the volunteers in the events section guys, we need all those spots filled for the day to go ahead.
really stupid question, but is there a safe place to put ur spare tyres and the jack etc..or do i need to get my bike chain??
They'll be right man. You can just stash em behind one of the buildings. tyres and jacks (unless if they're really good ones) would be safe. If you value them a lot then get a chain.
yea so?? iv never done DECA before. its how u drive not how powerful the car is..well sorta
iv only got a fmic, 3inch, coilovers and pod...close to stocki...lol
180sx battles are on...who else is in???
hehe
yeah man... i'm in!
Any positions still available for this?
I have a feeling my membership is coming in the mail for occasions like this!
according to the 1st page there is 17 positions left....get in fast, could be 17 but in 2hrs it could be 10...
i just dont want to have a mad day and kill my tyres and come to change them at the end of the day and ONE scum stole my tyres and my dads jack!!
*now were is my bike chain*
i left my stuff un attended for the past 2 DECAs and nobody took anything, i even left my phone and camera by the side of my stuff.
most people that go there are members and i dont think anyone would take anyone elses stuff
DECA is very easy on tires, i am still on the same set of tires since my 1st DECA and i drive my car daily as well, so you may not need spare tires unless you are running realy low on tread
Yeh mate alot of the guys/girls that attend deca are of the more mature crowd, people are really nice and always willing to lend a hand.
When you get there you leave your sub, your spare, jack and tools in the car park.
Great day out!
Guest
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
