So the night before, someone stole my valve stem air caps.... I wake up this morning and find this...
What the f**k. I've had the worst run of luck lately... and I've only had my car back for 2 days. I would think that I live in a relatively safe neighbourhood (Caulfield South) and have never known trouble like this... ever.
I only hope Karma will hit the person who did this and hit them hard... else a baseball bat, either is good.
Luckily for me, I've managed to secure a window and it will be getting repair by today... still... theres a little damage to the roof which I think won't be coming out... and an even emptier pocket for the damage...
https://www.sau.com.au/forums/topic/277913-senseless-damage/
I don't think so. I've got pretty good neighbours... could be someone across the street... it happened at around 12:30am last night... I dunno.... *sigh*...
The feeling of violation is just so high and rampant right now...
Best of luck with the repairs. :P
I'm assuming its just someone who has way too much envy for your ride.
Just out of curiosity - Was you car on the street? Were there any other cars vandalised? Reason why I ask is I remember there was something on the news a few months back in regards to random cars be trashed in the eastern subs.
Yep, car was on the street (the one night I got lazy for going up the ramp into the driveway). There were no other cars damaged. My brothers 4x4 was directly behind me and it was left unscathed.
I think they must have seen the r34 and thought "Damn, gotta beat that thing in"
Police came by, took some pictures and basically said bad luck. I don't blame them, I doubt there is anything they could have done anyway. I still have the brick which they used... wonder if I can place any curses on it which will rot testicles?...
Thanks for the kind words Ash... I've got a guy still outside fixing it. Hope it turns out like the original or better? hahaha
Yea, theres glass all over the interior. Shards of the stuff... a bit worried I'll cut my ass when I get in but it should be all good.
Luckily they didn't manage to get the brick through the glass so no interior scuff damage and such.
I'm a little worried about the dint on the roof just near the glass... its small but annoying. The glass repairer has been slowly edging it out for the past 20mins. Prob the more pro guy I've ever seen.
if its a small dnet try one of them mobile paint less dent removals. they work a treat. havent had the need of one yet but my neighbour got a dent the size of a 10c piece removed near the corner of his door
problem is it's on the roof right next to the glass and they need to be able to wedge the tool underneath the panel... so apparently they can only do it when the glass is off for the R34's... which is a bummer.
what I don't understand is why people do the stuff to skylines...I mean surely if you're jealous of a ride there are more 'envious' cars to own.
I mean strictly speaking price wise there's much more expensive gear out there like the european cars that I don't believe cop as much flack. Even a new HSV/FPV is going to cost more than most skylines so why bother?
they didnt take the brick for finger printing ?
cops just getting lazy these days. only source and they leave it behind.
bad luck there Ben, and glass on the dash ?
Pretty sure bricks make for very poor print sources, as they need a smooth flat surface. The rougher and uneven the surface the less likely they are to get an even print.
To the OP; I had something similar happen to my R33, and I live in one of the nicest suburbs in Melbourne (Mt Eliza). They missed my windscreen, but put a huge 50c sized dent in my roof just before the windscreen. Took the paint off and everything. Panel beater told me the same thing; he'd have to remove the windscreen to remove the dent, and he couldn't garentee that he wouldn't break the windscreen in the process. I was quoted like $500-1500 depend on whether or not the screen broke.
f**ken hell Bez, thats a bitch!
How the hell did they pull that off without someone beating their faces in??
The cars out of action until friday. Need a panel beater to fix the dent on the roof before the glass goes in. Sigh....
i feel your pain, was driving home from girlfriends place the other day, decided when i was close to home that i was far to awake to go inside and go straight to bed, so i went for a small drive, and got egged... took off a fair bit of paint on the bonnet! ..... now wish that I went straight home!
hope your luck gets better mate!
Apparently, these incidents happen a lot, and vandals are hard to trace. Do alarms work?
Even if they do, the people that commit this stupidity always make a quick dash....
One possible, but unfortunate solution would be to install micro cameras with infrared connected to a car PC or PVR of some description.
question still needs to be asked:
So do you drive like a dickhead, and, being a conspicuous car (and number plate), you've pissed someone off? Be honest here.
while there are "random acts of vandalism", there are many more provoked ones...
still feel for you though.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
