Whatever is happening, its obviously dumping too much fuel into the system. So, check your plugs- is one black and the rest golden? Or are all equally black?
As deep dish said- stuck injector could be the issue. Or it may be one of the temp sensors to the ECU has broken, and its sending coolant temp of -10 degrees or something to the ECU all the time, rather than the actual coolant temp.
Is the battery nice and new, and charging? this can cause some funny electronic issues.
My suggestion would be to take it to a mechanic that can log the ECU data, and look at it to determine the over fuelling fault.
  • 7 months later...
Hi guys, sorry to did up an old thread. I've recently purchased a VQ25dd Stagea, and having to do a few things to it i've got a warm start problem and sometimes it takes forever to start, but fires fine when cold. couple guys said to do the intake clean and egr blanking.
So i followed whats in here, ( egr bolts a terrible to get to ) and the intake was caked up along with the TB. I'm going to steam blast the covers and acid tank what i can and de-grease the rest. Couple questions i had,
With the EGR valve i want to remove it completely and run plates over the plenum and up pipe? what do i do with the egr valve plug, leave it empty?
With the resistor to wire in, i understand it needs to go into the grey 2 wire temp sensor ? can the sensor not be used as standard, why does a resistor need to be wired in?
and all the hoses that run between the egr, plenum and TB what do people do with them?
Thanks guys.
Just blank it off with a plate between the egr and plenum, if you remove the pipe you would have to drop the exhaust manifold and weld/bung up the hole, you won't do that once you see how hard the manifold is to drop...
If you remove the EGR you would need to drop a resistor over the plug so the ECU doesn't throw a fault code. Same with the temp sensor.
You may have to remove the lower plenum and lower runners as both will have been heavily gummed up with carbon. There are butterfly valves in the lower runners to promote swirl in the chamber, make sure they are clean too. It sounds like your throttle is gummed up hence the warm start issue.
Thanks for the prompt reply. i was going to bolt a plate over the up pipe so i didnt have to remove the pipe from the manifold, reason for removing the egr valve was because those 2 bolts that go into the plenum were hard enough to get off i didnt want to have to do them back up.
if i was to run just a plate and keep everything plugged in like factory would the ecu through out a fault code, or just open the valve and nothing happen further?
I noticed the little butterflies in the runners, wondered what they were there for. i'm going to remove them now and clean them off the motor. Yes everything was caked up in there. once im done i'll run some cleaner through the intake to try clean the remainder ports to the valves.
I would try and clean as much as you can before you bolt the lower section back on, you really don't want all that crap in the combustion chamber. Blow it out with an airgun perhaps. Just remember one or two of the valves may be open...
It will eventually throw a code anyway I think, as the temp sensor won't be seeing hot gas go past. Perhaps you can fix this with a resistor, not sure as I have never had my DD running.
so with the covers i steam blasted the top cover cause of the temp switch and other crap on it i didnt want to drop it in the tank over night. but the bottom cover got a tanking and ended up like this after the carbon build up.
Now i just need to remove the lower runners and steam clean them, and clean the ports out. also degrease the TB. then put it back together with a couple blanking plates and resistor.
Top cover
Bottom
Does anyone know the wattage of the 10ohm resistor? i dont want it to small that it overheats and fry's itself, and i dont want it to large to draw to much from the ecu and damage that.
As an electronics technician, I can say that fitting a higher wattage resistor shouldn't cause any harm, it won't pass any more current than a low wattage one. Assuming a maximum of 13.8V on one side and earth at the other, the power would only be 1.90Watts. Chances are there will be less than this in practice. Ohms law takes care of that. As an owner of an M35 direct injected VQ25DD, I'd be very interested in seeing pictures showing the connection points of the plugs/sockets involved in this mod.
Edited by Spong
1. 10 ohm resistor bridged temp plug of EGR cause ECU wont open valve and no errors
2. between the EGR and plenum blank it off with a plate
3. you can also cut the pipe that comes down to exhaust manifold and bend the bottom end down ( you can unscrew the pipe =EGR > exhaust= cos it has a thread on the bottom) in order to block any fumes coming up from the engine.
4. take off two rubber pipes that warm up EGR valve with coolant and attach together by any cooper pipe
Hope it will help :yes:
Edited by Nicko_2010
Great, so it is possible with a simple resistor to trick the ecu.
Personally I would be leaving the pipe intact and simply blocking it off, just in case you need to go back. It only takes one cop to dob you in to the epa... Make sure everything looks as per stock.
So yesterday I got it back running, fired up fine. Idled a little high but was a cold start. Then as it warmed up I still had warm start issues a little to the point were it wouldnt fire at all. Once I got it going the idle was around 1100. Today I'll try reset the ecu, re learn throttle pedal and idle. Hopefully it starts for the idle learning once warm.
Also still have a oil leak on the left hand side I need to source.
ok so done the ecu clear. then done the pedal check, and also the Throtle check, then i done the idle re learn. and its now sitting at 650-700 all the time. very happy about that. but i still have the warm start problem where i think it may be fuel related. so where's the fuel filter on these? might change that to be sure and then work to injectors and hopefully not pump. also might have to do the plugs while im in there. is there any copper altenatives or do i need to fork out for the expensive ones?
Fuel filter is wrapped around the fuel pump, located under the passenger side rear seat. Might need to go to Nissan to get a correct one, cause I don't know if DD motors run a different setup.
Iridiums are cheaper from the us. But take a while to post, if your using cheap shipping.
If it's a DD, you are supposed to run special plugs, not sure what the difference is but you could perhaps be able to run the LFR5's with no issues. If I get time I will compare the plugs for you.
The only copper plugs I have seen for VQ's were the same price as iridiums anyway. You should be able to source a set of LFR's for around $60-$80
  • 4 weeks later...
Today Dad and I opened up my 300gt. It has 46,000 kms and there wasn't that much crud. we only took off the top half of the plenum and cleaned it out, it didn't seem worth going any deeper. There was a small amount on the throttle and we sprayed carby cleaner on it and it got rid of most of it.
It all went back together no worries, it idles fine, and started first time.
And it has reassured me that the kms are genuine.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
