Hi,nice to meet u all down there. I've a question about the coolant.
"Heat is turbo car killer, right" And most of the people said that add 50% of coolant and 50% of water into the radiator,and that is the correct formual, right. Here is my silly opinion.
If add 60%of coolant and 40% of water into the radiator, will it be more effective for cooling down the engine?
Or 55% of coolant and 45% of water! So i wonder is anyone has that experience about that. Becasue soon i need to flush the radiator and change the coolant. Therefore, i had that idea in my mind.
Cheers mate
Steven
https://www.sau.com.au/forums/topic/27793-question-of-coolant/
Well the last time I flushed a radiator I used 100% coolant, purely for its non corrosive nature, I dont know if it would make a huge difference to the ability of the radiator to exhange heat - in I doubt it very much.
I was under the impression that coolant served two purposes, to extend the boiling point of water and inhibit corrosion.
water is actually more effective at cooling
but it corrodes like there is no tomorrow
also the coolant acts as a layer in the system to the water doesnt boil like crazy
btw u can buy antifreeze antiboil seperate or as a 50/50 mixed solution
The higher the concentration of glycol in the system, the lower the heat transfer capability of the coolant. So if anything you would want to _reduce_ the coolant concentration to ~30%. No less than 20% howeever. But in either case, it wont have really any real effect on turbo temps on the street.
Alot of ppl get confused and think the glycol (the green shit) in coolant does the cooling in the engine. On the contrary it actually impedes it slightly (compared to straight water) but offers antifreeze/boil protection aswell as caviation/corrosion protection.
Yep, you have pretty much hit the nail on the head, Busky...
Aim for between 33% - 50% Ethylene Glycol mix, as this has a good balance of the superior heat transfer ability of water and the advantage of a broader operating temperature range with the Anti-boil properties.
It's possible with 50% concentration to get a boiling point of around 109 degrees Celcius instead of the usual 100 degrees. This is good in the extreme case of a failed cooling fan, for example, and avoiding the possibity of hot-spot damage which used to badly damage the alloy heads of early RB30's and VG30's by cavitation...
When you buy coolant, read between the lines for the properties. An excellent concentrate will have at least 1000g/litre of glycol. Anything less like nasty cheapo brand ready made and diluted coolants have concentrations as low as 30g/litre. It's pretty much green cordial!!
Thanks mates. So i think it was my silly idea. what about change the radiator perssure cap, will it be help? Our factory cap is o.9Bar, what if changed to 1.3 Bar perssure cap. How's the effect? As i knew is, after changed the higher level perssure cap, the fun will open more often , and could keep the tempture down esaier. Is that right?
Cheers
steven:D
Nope. Another wrong idea.
The reason we use pressure caps is to hold the coolant at a particular pressure. A pressurised system will have a higher boiling point, say 5C higher at 1 bar (Im not sure of the exact figures). The cap will not allow the pressure to exceed its rating by bleeding off the exess into the overflow bottle so it doesnt cause damage to the pipes/radiator etc.
However its not necessary to increase the stock cap pressure unless your coolant constantly hits >95-100C and you need that extra anti boil protection. In most cases, you've probably got a stuffed radiator or a malfunctioning thermostat in order to warrant a higher pressure cap. Unless of course, youve got a T88 hanging off the side of a 2JZ and do circut racing or something...
Most coolants on the market are glycol based, glycol is more effective than water for absorbing heat..
More glycol more heat can be extracted from your engine, but your cars cooling capacity, must be efficient enough for removing
the heat from the cooling medium, so not necessary the more coolant the cooler your car can run, glycol will retain heat if you do not have the capacity to cool it down...
But bear in mind that if a concentrate glycol coolant were used over around 65% with water, you would actually have overheating problems. You are correct though about the car's capacity to actually remove heat in the first place. Not trying to sound smart, but glycol has the ability to stabilise and transfer heat more evenly than water - nuclear thermodynamics.
Here is some links to specs on good quality coolants:
http://www.nulon.com.au/content/tech_ll.htm
http://www.castrol.com.au/products/pdf/B11...reeze%20350.pdf
hmmm, you're not supposed to mix two different types/brands of coolants. reason being that they can actually react against eachother and accelerate corrosion. Should try to at least drain the radiator and undo the drain plug on the block. otherwise, drop the bottom radiator hose and drain it all and flush the whole system with a hose while the heater is set to hot and turned on. that way, you'll get rid of all of the old coolant running inside the car for your heater.
Lets clear up some issues....
Glycol is generally more viscous than water and has a lower heat capacity and thermal conductivity than water. Therefore has a lower heat transfer properties (than water) as the glycol percent (based on a water/glycol mixture) is increased...
These are the boiling points of a Ethylene Glycol mixture with water with E.G in weight percent mixture within the water
0% 99
10% 100
20% 101
30% 102
40% 104
50% 106
60% 110
70% 115
80% 123
90% 140
100% 160
Therefore using something around 40-50% sounds right.
I hope this helps guys!
:uh-huh: yeap! :uh-huh: spot on. although those figures will vary slightly depending on the brand and concentration of the ethylene glycol content of the coolant. I couldn't find a link for Tectaloy, but the Nulon and Castrol links in my previous posts point to what i consider the main players of concentrates.
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
