R33 Dash light and Stock Boost Gauge
Do you have a recording of what it sounded like at startup? Just curious to know what it sounds like.
Hi Tao, It seems that turbine fragments entering the engine is more of a thing with the twins. The theory is that because there is much more of a straight shot from the turbine housing directly at exhaust ports, they seem to cop it where the single turbo cars don't do it so often. It is definitely something that we hear about on GTRs far far more often than the others.
By soviet_merlin · Posted
How slightly is slightly? I wonder if we have different thoughts on what slightly turning left means. I just tried this out and on mine you can turn the wheel somewhere between 45 to definitely less than 90 degrees before it cancels. Though I have to admit it feels much slighter in my memory than it is in reality. See dramatic reenactment below. VID_20250126_143110.mp4 -
The overboost could be more of a cause. Broken turbines usually ends up in the cat, time to engine rebuild. Blown stock turbos can be high flowed with bigger and modern wheels for greater power goals.
