In all reality you can go a long way with std rods and pistons but honestly, if you pay someone to do everything properly you don't save a lot. Have a set of standard rods checked, new bolts fitted, closed and honed, pin bushes replaced etc and see what it costs. Then compare that to a cost of Spool rods, you might save $350-400, if that. Forged pistons will set you back maybe $700 more than a set of cast stock ones, maybe as little as $500.
Compare the price to re-ringing a set of 20 year old factory pistons and doing nothing to the rods and it might seem a big cost but if someone's going down that path the argument is pretty null anyway, the difference between doing it properly with cast pistons/stock rods and forged pistons/aftermarket rods is small. They might cost you $1000 extra but over the total price of the engine, it isn't a huge percentage for the piece of mind it gives you.
Well said, couldn't agree more.
Cheers
Gary
What have you done to the "stock" crank?
Cleaned, crack tested, no knife edging or lightening etc, just a oil pump drive and balancing, so stock as in not an aftermarket billet or knife edged or lighted crank, just as pretty much everyone else runs their RB30 cranks, nothing special about it at all.
Rob
Edited by R.I.P.S NZ
  • 3 months later...
  • 3 weeks later...
Buy some insurance here..
http://www.jandssafeguard.com/
I will be using it on my new motor...always a chance at getting a bad batch of fuel. Very hard to keep all bases covered on a servo fed street car. Advanced ECU's like the Motec M800 and Autronic SM4 will also enable you to engage over boost, fuel pressure, EGT, AFR, etc protection limits...the more insurance the better.
Matt
PS All for using a stock bottom end...to cheap to worry about it eventually breaking "if" you have the ability to rebuild yourself.
  • 8 years later...
7 years, 1.5 bar + 100hp NOS, 450wkw with nos, low 10s, 7200rpm limit, stock bottom end with new rings and bearings only.
the power your after is effortless on stock pistons, its all in the tune.
Hi rob, remember me ? I have your stock rips bottom end under my 26 big sump tomei pump, custom 2 stage catch tank setup, ati balancer. Currently making 658hp atw been running for 3 years roughly now
  • Like 1
  • 1 month later...
On 8/22/2018 at 6:27 PM, danny14 said:
Is yours still going ?
Mine has had some more work done, JE Pistons, Argo H beam rods, Jun cams, Blitz 4" intercooler etc and it's now a bit over 600 RWHP.  Same crank, head, block, oil pump, water pump and a lot of ancillaries, oil cooler, radiator, fan, BOV's etc.
Cheers
Gary
Cheers
Gary
Holy shit, you've come back from the dead haha
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
