Beltronics STI XR Radar Detector
I imported this from the US in 2007 for $900 and have used it a handful of times on Australian roads. It has proven to be quite reliable for highway driving and I've successfully detected radar traps several hundred metres in advance. The 'auto-scan' setting can be temperamental in built up areas as the X-Band frequency can overlap with some remote security systems. This unit also includes Bel's 'TotalShield' technology which effectively removes radio frequency pulses making this unit immune to Australian RDD's including the Spectre III. There is some conclusive testing of these facts conducted within Australia at dontgetcaught.com.au.
Features include;
  • Exclusive TotalShield™ Technology
  • Dual Antenna Design
  • Multi-Sensor Laser Protection
  • Digital "POP" Radar Alert
  • All Australian Radar and Laser Band Coverage
  • 360 Degree Protection
  • Digital Signal Processing (DSP) Virtually Eliminates False Alerts
  • Clear Digital Voice or Audio Alerts
  • Mute and AutoMute Audio Controls
  • Brightness Control with Dark Mode
  • Magnesium Construction
Unit comes with;
  • Owner's manual
  • Coiled SmartPlug™ lighter adapter
  • Amplified 12-volt speaker
  • Direct wire SmartPlug™
  • Durable hard-shell metal travel case
This package does not come with a Windshield Mounting Bracket or Sunvisor Holder but both are available separately for $19 (links enclosed). If you want more information on the device, detailed specs can found on beltronics.com
Price is $550 o.n.o.
Item is located in West Pennant Hills. Please contact Ed on 0438 131 464.
https://www.sau.com.au/forums/topic/278015-beltronics-sti-xr-radar-detector/
    • Only reason to keep a MAF on your RB25 is to be able to easily calculate true VE if you know what the factory voltage curve represents in grams per second of flow. Also allows you to do things like pull the original OEM ignition + AFR target tables and use those as a starting point for your base map. Once you're well and truly done tuning though there's no need to retain the MAF.
    • Do you think they'll merge there performance divisions and we'll end up HoMo?
    • Very true, if buying new, I would not get an PP either. Minimum is an Elite 2500, which is also considered outdated. Get something that supports DBW, delete that cable throttle. Best thing I've ever done to the Skyline, next best is refreshing the A/C with a new condenser. It's cold, but not as cold as modern car, but colder than most 90s JDM shit boxes imported into Australia.
    • Haltech have a nice comparison table between the Elite and Nexus models -  https://www.haltech.com/ecu-buyers-guide/ In general, the Nexus is better. Haltech have some nice product videos on their YouTube page, I'd have a look at those and if you're still not confident what way to go, I'd give them a call. They have the best customer support of any company I've dealt with, I'm sure they'll be able to help you out.
    • Not to mention, that the correct diagnostic approach to "electrical thing does not work" is to start with what I outlined above. You only do swaptronics for things that can't be tested really easily, like ignition coils, AFMs, etc etc. And even then you hold your breath in case the fault that possibly killed the original unit kills the swapped in unit too.
