Ssr Professors And Work Vskf 18"
It's because the air comes in over #3 & #4. The two "dead" ends of the plenum are at #6 & #1, with #6 being a little more "compromised" (Sorry about all the quote marks) than #1, due to the shape. So you get the dead end effect at #6 & #1 where dynamic pressure converts to static pressure, likely causing the air flow to be highest for these. The others are then just working in from the ends to the centre. 6 -> 1 is only valid for FFPs.
Cut back on the attitude champ, no one is obligated to help you. The chances of Forester owners on here are quite low, considering this forum is called Skylines Australia. https://www.subarupartsdeal.com/parts/subaru-under-cover-front~56410sa000.html ^ that picture looks wrong, because if you see the diagram, 56410SA070 looks correct. You can always check where the mounting holes are on your car, and compare them to the pictures.
Hey Duncan, I've always set them up from 6 -> 1. Due to slightly higher EGT's, I also add a small amount of fuel to cylinder 6 & 5. I understand why you start at 6 but curious as to why you then continue somewhat based on firing order? Thanks -
United E85 is always 85% ethanol. At least it claims to be. But that goes out of the window about thirty seconds after you put a tank of it into your car and can't do the math to determine if you have 76% ethanol, or 47% ethanol or 26% ethanol because you put 33L in, then 16L in, then a full tank of 98, then "Some" E85. Ethanol tunes that aren't full flex or full E85 all the time are just absolutely a waste of time. Don't be stupid and ruin your car.
By Watermouse · Posted
I don’t mean this in any negative way. But, if u are after this type of data why don’t u have a flex fuel sensor?
