I started puting the seat mounts in on Saterday. I've cut the standard mounts out, and so far put the front drivers side mount in. used some 3mm plate as a base, and 25x25mm rhs to go between the sill and transmission tunnel. i forgot to take the cam on sat, so i'll try and get some pics today, and put them up.
some pics of new toys
Haltech Platinum Sport 2000, and Racepak IQ3 logger dash. Better value money than a heap of gauges, also neater and easier to mount. Also can kill the engine if oil/pressures drop (right foot dosn't always obay red lights)
Cheap carbon boot, slight damage in the top right made it much cheaper
I got my Navigators seat mount in today. Got it to sit really far back, pitty the exhaust was in the way, so i couldn't get it any lower
Also removed the ignition barral, and steering lock.
Damo started stripping the loom out
Also got a ABS unit out of a VY Commodore.
Very cool Ben, gee wiz your passenger seat is going to be a long way back. I mounted mine on the hump so the passenger sits a little higher than me but i will not have one very often.
What's the idea behind the VY ABS unit?
ABS is very handy for tarmac rallies. especially when your tyres have to last for 5 days. And the standard Nissan unit isn't very good (late 80's tech vs 00's tech). And ABS from a local car is easy/cheap to find from a wrecker, I only paid $110 for the unit.
How do you go wiring it up?
fair enough.. with a cage like that, i hardly think the extra few grams of steel would matter :D
i will be doing the same no doubt... as like you... i have a large sheet of alloy, sikaflex, and no a/c.
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
