regardless of gauges or no gauges we have simply offered up some free info that has taken time and money to get. we used 2 different examples ect ect. take from it what you like. we will take that its simply better not to have to change engines the night before or during events (which is when we have had to do the last 2) and if your half capible a simple mod to the sump will stop that.
ironicly - My old drift team mate spun a bearing the first time he drifted after fitting an oil cooler. i blame the cooler 100%
You saying the cooler reduced the oil pressure to much?....
Woo aren't you installing one... Better touch wood!
The workshop putting together an external oil pump kit for me strongly advised against using an external filter block due to the poor design. Can't say I paid it much thought at the time given the number of folks running them but these guys do build a lot of race/drift motors.
Hypercry?
By external filter block you mean the block adapter or remote oil filter kit?
Also keen to know thoughts on the oil cooler causing failure!
I've got one coming with a built in thermostat
I think the comment was made with sarcasm... The same way the rest of us were taking the piss and blaming the gauges for wrecking motors...
I've been a bit slack cause it's been too cold. But the replacment engine is pulled down to install the restrictor, and mod the sump.
We had a high pitched squeel all event. We knew it was a boost leak, but considering everthing else we couldn't be bothered. After I pulled the car appart, I found the source of the leak. I had put a incorectly sized bolt clamp on, and it didn't seal evenly.
still considering it, i'd like to have a good look at one of them. But Damo and I have worked out how to VVT a normal RB20 head, just would come down to funds, and if this new engine needs it.
Did you consider a secret handshake V-Cam RB20 :) or are there elegibility problems with running a later model head, series of engine?
i had a bit of a think tank and dragged a coupple of old heads and bits up from storage and worked out that if the gains were there to be had it was easy enough to make vvt work on a rb20 head. without modding the head. i took a bit of insperation from the HKS V-Cam and sussed it all out. i supose people just dont see the point developing rb20 engines but for us having to fit within engine size rules we have/ want to think outside the square.
i think the whole project is just bringing good ideas from everywhere and putting them on one car.
the super f1 spec engine is has actualy suprised us both in its designe.
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
