So itโ€™s been over a year since an update.
The first event last year was the Poatina Mountain Race, it was pretty much a 7km hill climb with the option for a navigator. I put my girlfriend in the silly seat to call the notes. We came 5th outright, and were the fastest 2wd car up the hill for the day.
The next event was Targa Tasmania. As the car was going well I didnโ€™t make any changes to it before the event, just freshened up the parts. But I did have a new navigator in Julie Winton-Monet. For the first 3 days we controlled the early modern competition. We won every stage on the first day and ended with a 30 sec lead.
On the second day we won all bar 1 stage and put another 30 secs on the field. Happy with our 1 min lead we backed off a bit and kept an eye on the times so we could slowly pull a gap, while being easy on the car. Our main competition had an oil pump failure, which gave us a 7 min lead at the end of the day.
Day four was really wet, so I put my green tyres on and filled the boot up for extra traction. We took off from the first stage and the alternator light came on, I turned everything electrical off I could and limped to the end of the stage. I got out and checked the belt and checked the plugs on the alternator. But it was all over, the battery went flat. The voltage regulator had failed. We got a jump start and limped along behind the field for the rest of the day dropping 30 mins.
We replaced the alternator and attacked day 5 at full pace. It was another wet day, and it turned out that the car is pretty good in the wet. We were 3rd overall on the wet first stage, only 5 secs behind the winning R35 GTR, it was our stage of the event. The stages ended up drying out and we won the last stage outright, which we were pretty happy with.
Targa was a what could have been, but sometimes thatโ€™s just how it is.
10580838_720072244731439_227152757468877
10553699_720072151398115_304434144055389
10552466_720071921398138_836836185488384
I had a lot of problems for the next few months. I blew a head gasket 3 weeks after Targa. So I pulled the engine down and found the head was damaged from valve float. I got that repaired and put new rings and bearings in the engine.
Next event the diff exploded, turns out when you take a diff to be checked, it means reset the pinion to the wrong position. When I had the car apart again I noticed it had pushed a heap of coolant out. I had to pull the engine out and get the block decked. I hadnโ€™t checked it properly when it was apart the first time.
I put everything back together and headed to the Legerwood Lane hill climb. I finally had a good event coming 2nd overall and fastest 2wd.
Next event was the Phillip Island support race for the V8 Supercars, which would be my first ever open race meet. I loved the track. My fastest lap was a 1:43.9 which qualified me 4t, there was more time to be had, but I ran out of laps. The car was way too soft, it was still in full rally trim, but I had to live with it.
I finished the first race 2nd after 2 people dropped out. I finished the second race in 3rd and hit a seagull going over the start line. Last race I came 3rd again after some wheel to wheel on the first lap. I got 2nd overall for the weekend.
1922089_795179067209832_4465319367135263
1533733_782811248457538_3069334423641519
1459143_782810905124239_5375044671092430
Edited by sav man
  • Like 4
Next event is Targa Hellyer Gorge in 4 weeks. Targa have released new regs, which mean I need to add 100kg to the car. I'm currently putting the weight in, and re-springing the car to suit
EPIC!
Re Targa. You have had a few problems with alternators haven't you? Have you seen those $90 lithium jumper packs? Keep two of those in the car, they are only the size of two old VHS tapes. Hell, I would wire up a dual battery setup so at least if the alternator goes you can get through on battery power. What is another 8kgs?
We had a problem that the standard alternator couldn't drive the heated windscreen. I got a maxima 110a to drive it and that's the one that failed. I disconnected the passengers side of the windscreen to get round the current draw issue.
With the new regs I will be carrying a lot more spats
EPIC!
12V Lithium jumpers for $90? Where can I find these?
Spats or spares? BTW what were those green tyres you mentioned for the wet? Cheers
Spares is what i meant.
We are able to run 8 tyres for Targa, so my plan was to run the first set into the ground, and save the new (green) tyres for the end or the wet.
I run Dunlop D03 in R2 compound
  • 1 month later...
I converted my car to the new Targa regs a couple of weeks ago. I bought 80kg of lead from the scrap yard, made a mould and melted it down with an oxy torch.
7E8903C6-625B-4D40-A9A9-14008862464F_zps
9249F095-2E6D-4940-9195-E244732CD1C3_zps
The car now has 51:49 weight distribution, which has given it awsome drive, but it understeers like a pig. Once I get some new springs and a rear sway bar it should make it better. Rear shocks will probably need a re-valve too.
I ran Targa Hellyer gorge last weekend. I ended up changing the lift and pressure pump during the event, as the 044 got very noisy, so I replaced it, then it got noisy again. Turns out the lift pump was failing and filling the surge tank while I was idling around, but but running out under load. The event also gave me a starting point for the new regs, so I know what I need to change to make it faster.
10960299_863144057041966_398360849286384
Edited by sav man
Is there something in the regs that says you have to run it inside the cabin? Personally I would make the lead into 5kgs sheets/plates and bolt them to the underside of the car.
I always envisaged running it under where the back seat would go. Close to the COG but between the axles and nice and low. That way you can run perhaps 3 under the rear seat to two under the drivers seat. Lowers the the COG and can play with weight distribution as you see fit
yep now 1430 with driver and nav.
Regs say you can put it where ever you want, only restriction is on mounting plates and bolts. I was looking at putting the weight above the diff, but there wasn't enough room and it was going to be way too hard. The chassis rail is restricting the bricks being any wider as it is
  • 1 month later...
    • Good news!!! Changed the O ring today and Iโ€™ve got the โ€œpssshhhhโ€ back when I open the fuel cap ๐Ÿ˜‚๐Ÿ™Œ๐Ÿผ๐Ÿ™Œ๐Ÿผ It was 100% the O ring because that bloody thing was inside the fuel tank ๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚ Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But sheโ€™s running!!! โค๏ธ
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though egย https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
ร—
ร—
