I rate the F40s. I grabbed some 6 pot Alcons and got all wet over them until i realised they run 376x36mm rotors :P A bit bigger then i was expecting/hoping. Oh well, back to std brakes while the car sits in storage. One day....i will just burn it and build a track GTSt like Two Bens Racing
The pump unit in the 32 series is the same.
My GTR has Porsche 6 pot's on it, and i can still flat spot tyres with it.
I'd put a fair but of thought into a Tarmak Rally GTR, and if wanted to build the best 32, you'd fill it with R33 bits. The ATTESSA PRO ecu is day and night compared to the R32, heaps faster, ABS is heaps more responsive (but not too aggresive) , also feeds torque to the front wheels under brakes (found that from datalogging it) for stability, and a R33 transfer case to handle the higher baseline awd. IMO the biggest problem with the 32 is the old tech ECU's, it was bloody advanced in 1989, but tech came a long way by 1995, i think the pumps are fine, just the ECU that drives them.
A R33 ATTESSA ECU would be well worth doing, as you have better ABS, and AWD. I'm not sure how hard it is to disable to A-LSD in the ATTESSA PRO, cause that's the one you want. Only thing you'd want to consder is if the R32 tranfercase can handle running a little all the time.
On another note, where did you get the rotors for your F40's? Are they 2 peice, and 332mm?
The F40's (like most stuff on SAU) came from Roy. They are a good calliper & take a pad from the 4 pot Brembos on the Falcons of all things. Makes me wonder if all those Brembos on Foulcans can be put to better use?
The rotors are stock R33 gear, ie 324x30. Still trying to find a 345 rotor to suit & get bracket made. Project Mu don't quote the offset for their 345 rotor for the Nissan (Part Number FC44 N102A & FS44 N102A with the callipers dependent on which calliper). :ninja:
I found the bias to be a little too far rearward so I reckon the bigger rotor would be excellent.
The issue(s) I had with the ABS ECU are obviously that the cycle rate is rubbish but more so that the damn thing doesn't appear to actually release the locked wheel when you are on R compounds. Maybe the line pressure is too high but it doesn't function at all well as ABS on the track. Makes me wonder why bother carrying it.
R33 computers/ATTESSA looks like an idea. No need for the 33 V-spec stuff but if the povvo pack gear works on a 32 that would be excellent. Although having said that with the Ruzic controller there isn't too much wrong with the 32 ATTESSA - as long as it is shimmed to spec.....
Bugger, i have a 343mm bracket for the F40, though its buried in storage :) Dont run PMU 345s...lol for gods sale. Way too expensive., Grab some B-Spec 343mm x 32mm rotors. Good sturdy design and reasonably priced replacements and they are a very easy rotor to adapt the F40 to.
Depends on which hats you have. Alcon, Dixcel, Brembo, Stoptech all make a decent 332 x 32mm rotor. I guess you run Brembo so you can get Dixcel replacement rotors off yahoo or out of Japan. Since the dollar is doing ok you can consider buying new stoptech hats and rotors as the hats are damn similar but sadly dont take the Stoptech rotor (assuming you run a Brembo hat) It may work out more viable as the Stoptech replacement rotors are very cheap compared to many of the others out there
fgs, re bend those brake lines!~ my grandmother can bend tube better than that... =P
other than that im loving the suede dash and the build up in general... awesome stuff, best of luck.
are you allowed to replace all the glass with something a bit lighter like perspex?
im heading out to strip my '32 after being hit with a wave of inspiration hah ha.
Cheers, Rowdy
Cheers, Rowdy
Re brake line. Damo is not responsible for any of the braking system thus the level of workmanship is low. lol.
yep perspex can be used but its getting more like a dollar thing as im spending more money than ben had budgeted. i dont think we will have any issue getting down to the base weight for targa anyway.
Cheers, Rowdy
your grandma can definatly take pipe better than that, she's very good at taking pipe. :D
Edited by sav man
more update
Mounts 1/2 fabricated for the abs sensors. just need to drill holes for sensors.
Test fitting the dash
Damo straightening the fins on roys old intercooler.
Painted engine bay, now with some more wires.
Modified coolent pipe for under the plenum
dash looks good boys... will be doing mine this weekend.
ive read that the 3m spray glue is good to use also?? yes?? no?? dont know?? should i repeat the question?? or is selleys qwik grip the only shit to use??
using pegs is a bloody good idea too... must get some of them yes.
this biger question is will it be ready in 30 days. As those last 26 days will be used for testing.
Nah its only fun when your running in/tuning/finishing off interior on the drive to scrutineering!!!!
But yeh good plan!
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
