I got the clutch on today, I suffered major retardation and put the flywheel on without the dust cover when the engine was out of the car (and torqued it up properly). So i had to pull the flywheel off, put the dust cover on, and put the flywheel on again. Good thing we saved the input shaft from the R33 when it blew the gearbox a few years ago, made aligning the clutch plate easy as. Big bad RB20 box will be going in tomorrow.
it's looking very likely to be from some block called rodger for the usa, 3 way adjustible. been asking a local tuner down here who has set the suspention up a few sucsesful Targa cars, and he recomended Penske and Ohlins over MCA. Because the Penske and Ohlins engeneers will valve to the specs you ask for, and Murry does what he wants. The shocks them selvs are much of a muchnes, appart from the Penske and Ohlens being lighter than the MCA (aloy vs steel).
Ohlins is way too dear, and if the valving needs to be modified i've got somone here who can say the valving needs to be changed to be xyz, i need somone who will try to get al close to xyz as possible.
Got the gearbox in today.
Kerry's car looks nice, but have passed since it isnt registerable. I would consider an unregistered car if it had more fruit in the way of brakes, wheels and suspension...but since it isnt registered will keep looking around.
oh yeah, forget about that. Being in tassie don't think twice about a car with SI, makes it hard in Vic i recon.
Kerry's car is damn quick
you talking about is white one with a td06?
Edited by sav man
more picatuoos
extra lights on the dash (indicators, highbeam, fuel low, altenator warning, abs warning)
Center switch panel
Moding Reo bar to fit N1 slots
Test fitting front end, still needs some sweeking to fit properly
I'm going to build a GMS GTR like air intake system (over top of radiator) next.
Edited by sav man
  • 3 weeks later...
I got myself a GTR fuel tank on the weekend. Originaly got it cause i thought it would be lighter (plastic vs steel), but when i put it beside the Gtst tank, i found it was a fair bit bigger. I just found a service manual which says the gtst has a 60l tank, i'd just assumed it was 72l like the GTR. Should be all set for some E85 action now.
Also fitted the steering wheel. Planning to get some alloy donuts to make the intercooler piping up next.
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
