"I'll be converting the Crownie boxes to Alloy soon"
I'd love to see that magic trick... actually I'd like to see that magic trick in reverse! ha ha ha Alloy is cheaper than beer...
I cant wait to see the intake... If it works out well, I'm totally going to plagerise... ha ha
J.
  • 3 weeks later...
and in other news damo has been seen in the bushes around primary schools.
I've had a paint sceme in mind for a while now... and it's not painted like an animal, cars painted like animals look stupid, dad proved that.
Aw come on ben, not even something like this?
It's hard to get motivated when it's cold. I measured the suspension up today. Rear is easy to get good travel on. The front doesn't have alot of room for travel, you can only get about 60mm of travel at 345mm ride hight before the upper arm goes through the top of the tower. I'll reserch and play round with the ride hights on paper before i order the shocks
  • 4 weeks later...
Now got job security, so it's back into the car.
I've ordered my air filters for the airbox (2x Merc 600SL), and a 044 to pump E85 goodness around.
Damo wired in the ABS this weekend
I got 3/4 of a alloy donut and started my intercooler piping on the
It's almost ready to weld, I didn't take pics of the last section, but it just needs the ends tidied up, then off to the welder.
Also got the seat mounted
ben beat me to the pics but i thought id add some more pics to assist with other people wiring cars.
I use deutsch plugs for most of the bits that need plugs. these are by far the best plug you can buy. weather proof and higher current carrying capabilities than other similar sized plugs.
this is how they go together as such. this example is a plug for the ABS wheel sensor. the wire is 16gauge Mill spec is in PVC sleving which is my profered looming material. it makes the nicest neatest job of any loom but is a pain in the ass to do and probably adds 50% more time to any job.
next ois what i started with regarding all the ABS wiring
this shot shows that there is 2 looms mearging into one. a pice of heat-shrink is then slid over the top and once the 3 bits of PVC sleving are pulled into one the heat-shrink is then heated forming a seal between them all. On engine looms i use doubble walled heat-shrink that has a glue inside of it. when heated the glue goes runny and the heat-shrink pulls tight making some of the glue ooze out the end. this give an almost water tight seal and prevents the PVC sleving from pulling apart over time.
ill get a few more pics in the next week or so of the wiring into the switch pannel and fuse boxes.
I made the turbo side piping today. it's almost ready to weld up, but the pipe that damo supplied wasn't long enough...apparently this is a normal occerence. Another 50mm or so of pipe should fix it.
Got some sensors for the Haltech (oil temp, oil pressure, fuel pressure, exhaust temp)
Air box MKII with one of two filters in. pretty much a copy of the GMS one. Need to get some alloy and make it now, and then design the top 1/2.
Got the intercooler piping ready to weld today. Took ages to file all the joins so there wasn't any gaps... welder says it makes his life much easier.
I got a surge tank during the week too
  • 3 weeks later...
I got some more work done on the weekend
I cut the airbox out, and bent it up ready to weld.
I installed the Aero catches. They are are pain in the arse to install, but it's worth it when there in.
Also installed the belts, and finished suiding the interior
I got a heap of speedflow fittings for the surgetank setup.
I'm putting bulkhead connectors in the floor or the boot, will make it neat, and i won't have to worry about hoses rubbing on the hole in the floor
I'll get some hose tomorrow now i know the lengths, and then the setup will be done
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
