Great effort I love the interior and the air box is excellent... similar to Group A GTR's no doubt where you got your inspiration from? Are you mounting the radiator lower? (I may have missed that bit).
Race Radiators in Vic are making me a shorter cross flow radiator. When I was at superlap I took a tonne of pics of the GIO airbox, and pretty much copied it
The Fuel system is now together.
Edited by sav man
Nice, im curious though, why you mount the the surge tank at the back of the car? just thinking in the event you backed it in would be about the first thing to go..
Not sayin you would back it it or anything...
it's about parralel with the tank, so there is probably more chance of the 73l plastic tank splitting, than a 1.5l alloy tank.
Main reason I did it was I wanted it behind the axel, and that was just the neatest/easiest place to put it.
photos are way to big ben. ive gone over my download limit just loading one page. homo
So every one. Ben is searching for a oil drain pipe to suit his rb20 turbo. if you have one please let hime know. he has $100 waiting for one.
more updates
The airbox is coming together.
Got my turbo back from being highflowed.
I got a split dump from damo, as he has a new turbo setup coming. It was a modified batmbl pipe, so I am putting it back to standard. I welded in the split pipe from being a screamer, to plum back in
Now I just need to extend the main pipe, and put a flange on it.
Steave the roofer made 1/2 of the cover for the parcel shelf
Fuel rail, and 800cc injectors in.
Some say it took steve the roofer half a pack of ciggies to make that. hes still got 1/2 a parcel shelf. 2 doors and 2 rear quarter bits to go.
it is however far better than ben or i could do as ben cuts stuff out worse than a pre-schooler and i cbf'ed
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
