seems pretty laggy, but I guess it doesnt really matter for a circuit only car
really? I wouldn't call it laggy. it reaches 260kw at 5,500rpm and holds it to redline. that's a pretty nice bit of power for a little 2L.
It's coming on hard from 4,500 onwards and is very strong by 5,000. so as long as you can keep it above 4,500rpm it will be hauling ass!
  • 3 weeks later...
Well after Targa I think it's time to get a gated sump after i ran a bearing the night before the event. I'm also going to rethink the breather setup to stop it blowing oil out of the breathers all the time, and last of all put some cam gears on to improve response.
I gained some motivation today, put the dead engine on the engine stand, and drained the oil out. There more than an acceptible amount of bearing on my magnetec sump plug. But I ran out of motivation when it got time to remove the sump.
Some incar from targa
Riana:
Cethana:
Nice vids...seems E85 is the way to go :)
I call 1bar @ more than 5000rpm laggy, but thats just me :)
and yeah doesnt make a difference on the circuit as long as its kept over that sweet spot!
Cant have everything in this world, and you dont make 260+rwkws from an RB20 unless you move the power band up over 4,5000rpm!
You so can have everything... You just need to shoe horn a V8 in with twin turbos... :D
So what were you doing the night before the event to spin a bearing and call oil surge issues?
Was at Baskerville raceway. I've now been over the datalogs, and the oil pressure keeps dropping to 0psi under brakes (didn't for targa though)
The lag wouldn't have been a problem if I was able to rev to 8000rpm, but the new engine had issues to prevent that, so I lost 1000rpm off the powerband.
Edited by sav man
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
