Top job at the railway crossing/dip think you were one out of only three cars that kept it pinned through there and the only car that produced sparks :thumbsup:
pics of said sparks? Gotta thank the Penske's for that, they handle big bumps like that with no problems
Now the car has been in a big event, I thought I better post some findings about the car.
1) You need a decent sump! From the datalogs, the oil pressure will constantly drop into the 0-5psi range under heavy braking (cornering and acceleration forces don't bother it). It only does it for less than a second at a time, but as we found out, you're driving a time bomb.
2) Spending money on good shocks was worth every cent. We probably only tuned the car 70%-80% of what it could be, but the way the shocks handeled the big bumps really surprised me. Coming from the Bilsteins in the GT-R (which I was happy with), it was in another leage.
3) airbox and radiator worked like a dream. Intake temps were only 10-15deg above ambient. And the coolent never got above 85deg on a stage, you could see the thermostat opening and closing from the datalogs. As the temp woudl go from 85 down to 78, then back up to 85 2-3 times over a 30km stage.
4) Fancy dash was worth the money. The data from the logs was invaluable during the event, and I found the dash clear and easy to read during the stages. If you're racing you will spend just as much money on gauges as a dash.
5) ITB have plusses and minuses. They have given the same effect as bigger cams, with a loss of power down low, but it does keep the power going right to 8000rpm (and beyond if you had the turbo for it). I personly hate the throttle responce from the std 20, I think it makes gear changes slower (waiting for the engine to rev down so the box will engage the next gear), and it makes the engine feel like it's attached directly to your foot. I'm going to try some cam gears, and hopfully that will give me some responce back..... but if I didn't need to drop the rev's back to 7000rpm from 8000rpm, I don't think it would have been as much of an issue. I don't think I'd recomend it for other people, but I personly think they improved the entire package.
6) catch can design needs more thought than just hooking a single tank up. Constant high rpm needs oil restrictors, oil air separator, thicker oil, and a return to the sump.
I'm suprised re the oil surge Benny. Mine did about 10,000klm of competetive driving before a big end went, but I'm blaming that on running 30 odd 100% pace laps in a Qld summer without an oil cooler! lol
Do.did you run a litre overfull?
I run it to the top of the hump of the dip stick, I think it's about a litre if not more. It seems all 20's will eventually run a bearing, just not as soon as mine.
We pulled the engine down last night, and bearing 3 was the one that died.
Yeah ABS works well, it's 4 channel unit out of a VY Commodore with traction control (tc isn't hooked up though). Idely it'd be nicer if it was slightly less sensitive, but you only really notice that on a circuit.
thought id post up some pics we got before and during targa
the day ben killed the engine.
This nissan flag poped up at least once every day during the event and was usualy acompanied with a toot of the horn and a bit of drift.
Stopped in queenstown. just one of the many stops through out targa
checking results. Gotta keep on your game
Belt up bitches
And almost to the finish line. Pre finish team meet.
5 and a bit days of racing the car pulled up pretty good.
Im pretty confident you will see this team about again.
Did the service crew take the pic of the Nissan flag?
didn't upload the pics of the car when it was waiting on Bradshaw bridge to tackle Arrowsmith.
I've got a new high responce bottom end ready to go. Just need to bash some restrictors into it, and sort a sump out. ASR looks the go for the sump.
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
