regardless of gauges or no gauges we have simply offered up some free info that has taken time and money to get. we used 2 different examples ect ect. take from it what you like. we will take that its simply better not to have to change engines the night before or during events (which is when we have had to do the last 2) and if your half capible a simple mod to the sump will stop that.
ironicly - My old drift team mate spun a bearing the first time he drifted after fitting an oil cooler. i blame the cooler 100%
You saying the cooler reduced the oil pressure to much?....
Woo aren't you installing one... Better touch wood!
The workshop putting together an external oil pump kit for me strongly advised against using an external filter block due to the poor design. Can't say I paid it much thought at the time given the number of folks running them but these guys do build a lot of race/drift motors.
Hypercry?
By external filter block you mean the block adapter or remote oil filter kit?
Also keen to know thoughts on the oil cooler causing failure!
I've got one coming with a built in thermostat
I think the comment was made with sarcasm... The same way the rest of us were taking the piss and blaming the gauges for wrecking motors...
I've been a bit slack cause it's been too cold. But the replacment engine is pulled down to install the restrictor, and mod the sump.
We had a high pitched squeel all event. We knew it was a boost leak, but considering everthing else we couldn't be bothered. After I pulled the car appart, I found the source of the leak. I had put a incorectly sized bolt clamp on, and it didn't seal evenly.
still considering it, i'd like to have a good look at one of them. But Damo and I have worked out how to VVT a normal RB20 head, just would come down to funds, and if this new engine needs it.
Did you consider a secret handshake V-Cam RB20 :) or are there elegibility problems with running a later model head, series of engine?
i had a bit of a think tank and dragged a coupple of old heads and bits up from storage and worked out that if the gains were there to be had it was easy enough to make vvt work on a rb20 head. without modding the head. i took a bit of insperation from the HKS V-Cam and sussed it all out. i supose people just dont see the point developing rb20 engines but for us having to fit within engine size rules we have/ want to think outside the square.
i think the whole project is just bringing good ideas from everywhere and putting them on one car.
the super f1 spec engine is has actualy suprised us both in its designe.
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
