I took the caster rods out last night, they are rooted. The steel sleave in the drivers side bush just falls out, and the passengers side has a 2mm gap all the way round. We thought the bushes were stuffed, but didn't realise how bad they were.
How will you adjust if you use the genuine ones mate?
Not adjust them, I think them not moving is better than being able to adjust them. When Berry was down a few years ago, he was saying how much better new genunine bushes are then whiteline etc
  • 1 month later...
time for a big picture update. Engine is almost ready to roll
ARP Studs installed
Head back where it belongs
Damo and I took to the exhaust ports with a die grinder.
Most of the stuff is bolted back up to it now, and the block in nice and silver.
Aim is to have it ready for the Legerwood Lane hillclimb on the 29th.
I've blocked one of the oil galleries, and fitted a 1.3mm restrictor to the other one (as per sydney kids guide). Not running a external return from the head at this stage, as most poeple that have done it found it doesn't drain very well. I have also put rb26 cam covers on to help the oil/air separation.
  • 3 weeks later...
i'm on the hunt for some 22mm hose for the breathers now
Its not 22mm but it will fit the 26 breathers, it what I ran on mine.
http://www.xtremeautoparts.com.au/shop/pc/viewPrd.asp?idproduct=160&idcategory=107
You guys doing targa again this year?
Yep entry is already in.
How easy does it stretch? ie does it go on and off easy, so you can work on the car?
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
