We quickly tested injector 2, and it didn't seem to spray correctly. It wasn't a definitive test at all. But Cylinder 2 melted the plug, so it makes sence that the injector was playing up.
Its frustrating that the engine swap costs as much as the RB20...even though they are cheap you still dont like losing engines. By the time you put an oil flush through, coolant, oil, timing belt and swap over pumps or new pumps....plus your time...it sucks to lose an engine! >_<
not sure yet, still adding it all up, and trying to work out why it leaned out. after i got the exhaust off, it was obvios that cylinder 2 & 5 were lean, as the ports were white, and all the other were black
Weird that it was only two!
I would be sendig the squirters off to be tested ASAP
but hey least you didnt pull your plugs out to find the biggest mystery since the Orient Express.
3 days ago these plugs were oily.
today...rust?!?!?!
lol....I think
After a chat to my tuner tonight, we have come to the conclusion that the plug was the wrong heat range (too hot), and the long pull along the straight overheated it and killed it. The exhaust port was probably clean because the valve was busted and raw e85 was going through the port and cleaing it. I have also discovered that the valves on cylinder 5 wern't seating properly, hence the clean port.
I'll get the injectors checked regardles.
I can either put high comp pistons in my DET engine, this would give me piston oil squirters, and a stronger engine. Or repair the DE head, and replace the piston and rings.
The pistons would cost $1190, and the machining cost is going to be the same either way I go.
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
    • Hope your all having a mean Xmas! If anyone happens to know any trick to using the insanely complex climate control system, I cannot get it to not be on dual zone no matter how many times I deselect it (will say it's not but both vents blow different temps). Also one side is always hot, one always cold 🤷
    • I'd be looking at the mentioned EFR kit, room to turn it up if decide on e85 (which we know you will) and be super responsive and fun on the street. OR https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/?srsltid=AfmBOorrJa2S76JR5ekXprxBOtU44a1UProbe64YaiVi9zTVp1Lj814w And add whooshy noise for extra fun C5 corvette prices are coming down locally here and a mate has a manual one and is a heap of fun on the street and track.
