On 5/4/2022 at 11:03 AM, Komdotkom said:
Is there also rumblings about partial refunds for competitors this year? I can only imagine the money which has gone down the drain for no event this year.
I'm going to try, if enough of us get together we'll have a better chance.  I think only 14% of the event was run
Targa give refunds 😂
Cracking Up Lol GIF by HULU
On 5/4/2022 at 10:21 AM, sav man said:
No idea at this stage.  I would like for them to go back to AASA.  The 200k limit is a joke, as all the incidents have been well under 200k.  This year was the first time I was checking my speedo on a stage, as I don't fully trust that the rev limiter won't overrun.
The problem is more when a car comes off the road that the GPS can't get a signal out cause the car is upsidedown or the antenna has been ripped off.  It then relys on car to car comunication, which can also fail depending on distance from the road and antenna damage.  I think there needs to be a failsafe that if a unit stops talking back to HQ that a stop and look for car instruction is sent to following cars at the last known location.  There is probably better ways, but the discussion needs to be had.
Yeah hopefully once everything has calmed down and reviewed they will come up with better procedures for rallysafe & incidents.
Having to always check speed is dangerous but at least stuff with efi/after market ecu can set limits.
While I think you've got SFA chance of actually getting money off them, I would hope that they would offer a significant discount on future entries. Despite the event not running in a competitive sense, I don't think the costs to the organisation will be much lower so from their point of view I don't think it will be viable to hand over any cash.
  • 3 weeks later...
  • 2 months later...
After the shit show that was Targa I lost all motivation for a while.  I'll put the big block in soon and replace the Haltech with a Motec.  I don't recon I'll make it to the mainland till next year, but challenge bathurst does look cool.
  • Like 2
  • 1 month later...
  • 2 years later...
I've still got the og shell in the shed and the new shell is almost ready to race again.  I've got a Motec M150 in the car and just sorting a driveline vibration and putting in 10mm fuel lines then it will be running again.
  • Like 1
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
