Oh yes I do rate a bit of gutter talk.
He doesn't moan Damo, but he did say you do when he throws a digit in ya foofa valve.
i moan at less than that Benny.
anyway this has taken a backwards step. Bens away thats why he isnt in on the action in here.
NO rain free weekends in the near future forecast so the progress is gonna be slowed right down.
damo's is more of an exited squeal, but a singe digit just dosn't cut it anymore.
I'll be back from Hoebart tonight, and i might move my car into the garrage, as dad's gtr needs to have painting and welding done, which is best outside.
plann will be to swap the diff out, and put the gearbox into mine next. And probably start on the wiring
Been following this very closely..
Im looking at doing something similar very soon too.
How did you electronically remove the HICAS system whithout making the steering go heavy at low speeds?
you will hardly notice the steering. but the idea is and its explained in the hicas removal page is that you remove the hicas lines ect then you will have the hicas warning light on on your dash. this is turned on by the hicas computer which is mounted upside down under the parcel shelf. most people disconnect the computer which interferes with the speed sensitive steering. to keep the speed sensitive steering there is one wire that turns the light on. you simply cut that wire and leave the rest plugged in and walla no light and the speed sensitive steering still works.
have a quick look through the tutorials as i think i put the wire colour to cut in the R32 hicas removal thread.
Ben will be running a R33 pump which if mated to the rb20 harmonic balancer will be heavy anyway.
Are R33 boxes allowed in Tugga Benny? i got ben a super cheap 20 box but id never run one if i had the chance after having a 25 box. i flat shift mine and all sorts, mainly because im unco and cant drive but its pretty cool when mid drift i can slam it from 4th to 3rd with no clutch.
the 25 box is also massively bigger in size and weight and im not sure a Rb2o would have enough torque to get going. LOL
Yeh im quite certain since the regs state the housing must be original, hence you can't use a 33 box.
yeah, right..
I already locked it out hydrolically, now its just time to remove the ECU and remove the harness from it.
There are two connector plugs n the back of the hicas ecu. I have already disconnected one from the ecu, the light is off and the speed seneitive steering is still working as the steering is still light at low speeds.
got a care package from japan today :happy:
hooray the box isn't filled with dirty hypermax. Brembo F40's, and R33 GT-R rear Bremo's, with rotors, and brand new Endless CC-R pads.
The F40's are bigger than i thought, notisbly bigger than std R33 fronts.
Well now I've finished Dad's GT-R, so i get to put my car back in the garrage.
But i've been buying some more parts from Yahoo auctions
Buddy Club P1 QF 17x8 (6.2kg each)
90mm Titanium exhaust
RB26 intake.
got a care package from japan today :down:
This is funny, you are running the same calipers as me, though i am runnng 343mm rotors rather then 324. I have a Trust Ti exhaust as well and the truly scry thing is i hve been looking for 17x9 QFs :)
there is a pair of 17x9 QF's on Yahoo now http://auctions.nengun.com/item/g79810064 , they look really good with the dish (that comes from the extra width), the qf's are pretty hard to find. I have to run 17x8 for Targa :down: I'm running 332mm rotors.
Edited by sav man
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
