i was just trying to scare everyone into thinking that ben had progressed faster then expected.
thats my rb25de head which is very similar to an rb20det head.
i will make a build thread when its on and working as i dont like to boast about things untill its complete. as it was i thought it was all good to go untill i found i had left a part of the manifold off during all of my test fitting. back to the drawing board for part of it but a night in the shed with ben and i working on it and we had it all sorted. its gonna be sick.
just another one to keep you all aroused
well i got to work on the car this weekend...hooray. Unfortinatully i spent most of it cleaning up the mess of it being left in the weather.
but the engine bay is nice and clean now. Brake booster also removed, i need to make a alloy plate to attach the master cylinder too
removed the rear 1/2 of hicas, and pulled the diff out so i can put the nismo centre in it.
waiting to be inserted
I'll be getting a set of wheel bearings next, and puttin the gtr rear hubs in, and abs front hubs in. And scouting the wreckers for a Auto VY commodore to rape and pillage.
Edited by sav man
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
