I started puting the seat mounts in on Saterday. I've cut the standard mounts out, and so far put the front drivers side mount in. used some 3mm plate as a base, and 25x25mm rhs to go between the sill and transmission tunnel. i forgot to take the cam on sat, so i'll try and get some pics today, and put them up.
some pics of new toys
Haltech Platinum Sport 2000, and Racepak IQ3 logger dash. Better value money than a heap of gauges, also neater and easier to mount. Also can kill the engine if oil/pressures drop (right foot dosn't always obay red lights)
Cheap carbon boot, slight damage in the top right made it much cheaper
I got my Navigators seat mount in today. Got it to sit really far back, pitty the exhaust was in the way, so i couldn't get it any lower
Also removed the ignition barral, and steering lock.
Damo started stripping the loom out
Also got a ABS unit out of a VY Commodore.
Very cool Ben, gee wiz your passenger seat is going to be a long way back. I mounted mine on the hump so the passenger sits a little higher than me but i will not have one very often.
What's the idea behind the VY ABS unit?
ABS is very handy for tarmac rallies. especially when your tyres have to last for 5 days. And the standard Nissan unit isn't very good (late 80's tech vs 00's tech). And ABS from a local car is easy/cheap to find from a wrecker, I only paid $110 for the unit.
How do you go wiring it up?
fair enough.. with a cage like that, i hardly think the extra few grams of steel would matter :D
i will be doing the same no doubt... as like you... i have a large sheet of alloy, sikaflex, and no a/c.
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
