i had a quick search this morning but running out of time.
has anyone changed there clutch on a rs4s and if so what did u use, how much and is it any good etc?
can anyone also confirm the rs4s has the r33 gtr box and front and rear diffs. if so, should i just be looking for a r33 gtr clutch or is the 260rs clutch more heavy duty for pulling extra weight?
any info or links would be appreciated. i have to drive my car quite slow to avoid the clutch slipping in high gears.
https://www.sau.com.au/forums/topic/278066-rs4s-clutch/
I put in a cushion button clutch but I cant remember if it was an xtreme or exedy. I am pretty sure it was a simple R33 GTR clutch. From memory, the heavy duty was a little cheaper but if you are thinking about more poer down the track an want to be able to launch off the line then go the cushion button.
I think the prices were about $1000 for the heavy duty and $1200 for the cushion button.
https://www.sau.com.au/forums/topic/278066-rs4s-clutch/#findComment-4699850
the cushion button on the stagea is annoying with the extra kerb weight and the pedal effort involved with the clutch we have (i'm sorry i don't know what brand it is). i would recommend a higher clamp organic based on our experiences on the street in this car.
my R33 has a Jim Berry mini monty (or whatever he calls it) with an organic plate and it is a pleasure to drive, light as stock and holding 280rwkw no worries. i can't wait to change the clutch on the stagea to one of similar spec.
https://www.sau.com.au/forums/topic/278066-rs4s-clutch/#findComment-4699856
I have the same Jim Berry clutch in mine. Was built for 300rwkw. It does not like 4-5000rpm launches. It slips and smells a bit, but does smoke all four :)
I think with flywheel machining and a few bits I was missing was around $850.
You do have to supply your old clutch for him to rebuild it.
Just remember they are "pull" type and cost more than push type.
https://www.sau.com.au/forums/topic/278066-rs4s-clutch/#findComment-4700090
wow this guy has got a reputation round here.
aight il give him a call today. so i take it it wont cost me an arm and a leg,to get my clutch to him and back. just sucks i need the car almost every day i might have to think about painting my datto and registering that so i can have the car off road for a bit.
ill be kidding myself thinking i can change it my self with out a hoist. i think there would be too much swearing and anger involved. anyone got a recomendation for fitment in adelaide? bare in mind if they have to pull it out and wait for the rebuild?
https://www.sau.com.au/forums/topic/278066-rs4s-clutch/#findComment-4701998
call jim and he will probably still be on the phone when your clutch returns. he does like to talk.
check with him whether you really need to supply the old clutch. i didn't for the R33.
i know what i'll be getting when my time comes then :)
https://www.sau.com.au/forums/topic/278066-rs4s-clutch/#findComment-4702088
aight gave him a call and from what he says he can build the gtt clutch that comes in stagea r33 gtr box up to 3000 puonds of pressure (stock only 1600). :laugh:
so i think ill go with that, now its just the case of geting it fited i mite try it myself, if i can get a car of my olds for a week or so.
cheers for the link guys
https://www.sau.com.au/forums/topic/278066-rs4s-clutch/#findComment-4703766
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
