WAIT... WAT???
whoever is the statistician at MSN should be shot...
80 percent of the people are between 18 and 30
and 63 percent of the people are between 18 and 25?
soooo the point of this stat is that 17 percent of them were between 25 and 30?
lol 17%? are you retarded?
80% are aged between 18 and 30...
of that 80%, 63% are between 18 and 25 and 37% are between 25 and 30
ambiguity FTW. I read it as 80% are between 18 and 30 and 63% are between 18 and 25, so 80 - 63 = 17.
i find it weird when i got arrested the cops to my phone to find evidence and they saw all the videos of me rippin burnouts and they didnt do anything..im guessing because it had nothing to do with why they brought me in :)
Actual article quote: "Around 80 per cent of drivers caught are aged 18-30 and 63 per cent are 25 and under."
Whilst the article doesn't clarify it very well I'm sure funkymonkey is correct. The above quote does not contain an "of that" reference, so the 63 per cent is meant to be taken from the overall drivers caught instead. The 63 per cent statistic would be somewhat unnecessary/uninteresting if they were quoting that 63 per cent of 18-30 were 25 and under, as this is somewhat normal under any curve of distribution (7 of 12 years = about 60 per cent).
Edited by Birds
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
