Thought i may aswell post some photos i took from in the car while driving up the mountian..
i did get asked to pull over to put on chains by some woman waving a stick. once pulled over i told the guy it was 4wd.. or awd as i took off (not in snow mode) it gave a good spin, i think the guy loved it..
now for the photos...
and the teaser.. friday morning on mt P
https://www.sau.com.au/forums/topic/278150-m35-to-perisher-for-the-weekend/
So jealous!! I was meant to go down for the weekend - so there would have been another M35 up in the mountains, but had to bail with too much work on!
I went to Niseko, Japan early this year and had the best snow of my life! So im hanging to hit some more pow!
We will have to make it a M35 convoy one weekend. I will be doing a few weekends from late July through to October.
I know there is another m35 (blue one from memory) traveling down to the mountains. Saw it last year just south of Bredbo.
Cheers
Andy
its worth the drive up, tho you need to drive up when its snowing like a mofo down low.. 1000m or so. to get anything like i got anyway..
i'd love to drive up early one morning for some skidz in the carpark.. tho they shut them i hear
hmm AWD snow skidz. any arx owners want to 'upgrade' to an open wheel diff? im happy to do all the work :)
You for got your tag line.... "will F#@k for parts" LOL
It is so much fun in a frozen car parts. Much harder to do it these days as they are all serious now and no fun is allowed.
Hopefully heading up to Bulla this weekend, got all the board clamps n shit sorted for my car now... i don't think there is a more fun perfect car for driving to the snow than the Stag :) 4wheel drifts doing 10khp haha hilarious fun
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
