gt3076R
Nissan housing on it
bolt is missing from the turbine housing
by Nissan housing, you mean OP6?
got a pic of the boost curve before the fix by any chance?
  • Replies 129
nah not the OP6
its the recast version bigger wastegate hole etc
sorry no pic of the boost curve
it hasnt been fixed yet because Im tossing up if im going to buy a .82 external setup now that the turbo is off the car
ok ok update...taken my car to c&v performance today...waiting to see how it goes.
I'm interested to see what C&V do with it. He tunes my car. Ive heard some bad feedback on him, but as far as i can tell, he's very good at what he does.
No messing around. No chit chat. In and out. And despite popular belief, he has plenty of experience on Skylines/imports.
Just make sure you let him know you dont want it tuned to within one inch of its life, coz he'll do it. lol
They do a lot of drag cars, and like to get every last drop out of them on the dyno. If you gave him free reign, i have no doubt you would find a nitrous bottle in your boot :P
That foe some people is a bad reference on its own, as a lot of these guys will tell you they get an endless supply of people wanting to talk shit with them all day.
nnnnnnnnnnnnnn newwwwwwwwwwwwsssss update, ok back from c&v performance and im pulling a ripe 280kw's at 19psi....droppping to in high revs 16psi...due to weak actuator(i was told). any other fix to this????
now...they didnt find any leaks but i suspect...that the last time i pulled apart the intercooler piping and put it back together (after the last dyno) i am presuming it was fixed then.
now im looking to get a 19psi actuator which i have been advised will give me a bit more power throughout the top end of revs as its falling off.
ive got to say....INSTANT, INSANE, BOOST ALL THE WAY TO REDLINE .
my semi slicks are frying taking off from cruising in second gear.
only downside i see..is that im getting knock of 40 when giving it stick...?? is that safe???
i will post the dyno sheet tomorrow...thanks for everyones contribution and help.
i will tell you all how it goes once ive put this bigger actuator in...dissapointed in the hks actuator as its not holding that wastegate shut...
any advice or direction to a 19psi actuator would be great.
level of 40 knock is reasonable levels of detonation - check the tune or just make sure all is ok
see if backing out 1 or 2psi removes that level of knocking, if so it might need 1 or 2deg taken out on the map somehwere
keep an eye on it (covered in the PFC FAQ) at 60 the engine check light will flash
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
