i had iridiums in my 33 when i got it, they were in there for 20,000kms and were stuffed. put in coppers and they were still fine after 10,000kms. so the reason why iridiums aren't any good is because they are a waste of money.
  • Replies 129
Iridiums are also not ment to be gapped as it damages the end of them. Since most are 1.1 they tend to missfire on high boost applications, hence why most of us run a pre .8 gap on coppers.
y is every1 so against T bolt clamps, they hold on hydraulic hoses on mining equipment fine with 1000+psi im sure they can hold 20psi
n id also like the hear why iridium plugs are no good, i was thinking of getting a set coz arn't coppers only good for like 10,000 clicks?
If you think the iridi's will last 100,000 like they claim - forget that idea.
In a stock application, ye probably, but in a modified one with extra boost - unlikely.
Why pay $120 for a set of plugs that can foul as easy as coppers anything can foul them really, eg: your fuel reg dies, there goes $120 in plugs.
And say thats only 15,000km's into the set, all of a sudden the coppers are worth their price because you change them frequently.
Plugs are like an oil filter, in a modified application change them often, this is a family magna your talking about.
whole heartedly agree...
my last set of coppers were pulled out after 20,000 just for good measure and were still running fine at the time. and that's with 300 very abused rwkw...
the set before that lasted just as long
and the set before that were iridi's and were thrown out after 5,000 odd
Then they most likely are platinums, not iridiums. Not many places keep BKR7EIX in a .8 in stock (atleast that's what i find), most keep the BKR7EIX-11.
EDIT: I just checked back a page and you said PFR7B, yep Platinums.
Edited by PM-R33
yes they come in both 0.8mm gap as well as 1.1, but if you get the 1.1 (which is the factory specified gap for rb motors) they recommend not changing the gap down to 0.8 with the iridiums as it can damage them.
awsome they were the answers i was looking for, so looks like im gna get a set of coppers. while we're on the topic of plugs, what part number do i need or what heatrange should i get and what should i gap it too. they're going on a usual sub 200rwkw rb25 running 10-12psi, im also gonna be changing to splitfires the same time as the spark plugs go in.
cheers
power is a simple calculation of
air + fuel + spark + compression = power
whats the tune like?
whats does the AFR look like on max load?
how is the ignition timing tuned?
whats base idle timing ? check it with a timing light?
got it booked in for monday to be seen by another tuner and have this issue diagnosed.
i dont think the turbo is out of puff as ive seen several other rb25's make atleast 270...and im finding it hard to make just up to 245-250rwkw at anything over 14psi.
plus im getting a massive pressure drop without any detonation...so how can it be producing hot air???
Edited by allthewaytotheskyline
found my problem (fingers crossed)
leaking exhaust gas out of a 10mm bolt hole kinda like a little wastegate that constantly open
which would explain why it would hit 18psi then come back down to 15psi
I think its going to go back into the car with a .82 external gate setup now its all out
also i found a crack at the wastegate hole .I dont think that would have been helping my situation either
    • Believe it or not, it's about right, remember it's also the 4AT which is worth a good bit too. This sounds along just right with everything else ever posted here on a stock turbo at reasonable boost.
    • Ok, thanks, legends. I'm hoping I don't need to pull out the window regulator. I was thinking when the window is out, the regulator mechanism shouldn't interfere with the corner piece and then be able to be removed through the speaker hole. Fit the new corner piece and then refit the window, and Bob will still be our uncle.
    • Sounds spot on. My R33 gtst with a bit of boost made 162
    • So quick update.  got my Nistune done from CMS and was a smooth drive back.    Shane at CMS is good with his work and car runs fine. Was worried my fuel pressure might be cooked as my fuel leaks on a full tank 😂 but apparently she held pressure.    I asked him to install the boost controller so I don’t mess anything up, and he was happy to do it. Old solenoid is still in there but capped off.  I will remove that from the bracket next weekend.    for now…. I am happy with my 168 KW 😂😂  All she got is the 3” turbo back exhaust and the BC
    • If the tyres were fitted when new, I wouldn't expect much over 5 years of use. Especially if the car lives outside full time.  If the tyres had been stored under ideal conditions and are being purchased new, I'd fit a set of already 5 year old tyres if I only expected to get 1 to 2 years of use out of them.  I've purchased many a set of new (but quite old) tyres from St George Tyres when I just needed some decent rear tyres to drift on.  Here is a pretty crazy example, can't say I've ever bought 11 year old tyres from them before though lol.  https://www.stgeorgetyres.com.au/momo-tyres-245-45-17-outrun-m3-official-product-by-momo-italy.html
