gt3076R
Nissan housing on it
bolt is missing from the turbine housing
by Nissan housing, you mean OP6?
got a pic of the boost curve before the fix by any chance?
  • Replies 129
nah not the OP6
its the recast version bigger wastegate hole etc
sorry no pic of the boost curve
it hasnt been fixed yet because Im tossing up if im going to buy a .82 external setup now that the turbo is off the car
ok ok update...taken my car to c&v performance today...waiting to see how it goes.
I'm interested to see what C&V do with it. He tunes my car. Ive heard some bad feedback on him, but as far as i can tell, he's very good at what he does.
No messing around. No chit chat. In and out. And despite popular belief, he has plenty of experience on Skylines/imports.
Just make sure you let him know you dont want it tuned to within one inch of its life, coz he'll do it. lol
They do a lot of drag cars, and like to get every last drop out of them on the dyno. If you gave him free reign, i have no doubt you would find a nitrous bottle in your boot :P
That foe some people is a bad reference on its own, as a lot of these guys will tell you they get an endless supply of people wanting to talk shit with them all day.
nnnnnnnnnnnnnn newwwwwwwwwwwwsssss update, ok back from c&v performance and im pulling a ripe 280kw's at 19psi....droppping to in high revs 16psi...due to weak actuator(i was told). any other fix to this????
now...they didnt find any leaks but i suspect...that the last time i pulled apart the intercooler piping and put it back together (after the last dyno) i am presuming it was fixed then.
now im looking to get a 19psi actuator which i have been advised will give me a bit more power throughout the top end of revs as its falling off.
ive got to say....INSTANT, INSANE, BOOST ALL THE WAY TO REDLINE .
my semi slicks are frying taking off from cruising in second gear.
only downside i see..is that im getting knock of 40 when giving it stick...?? is that safe???
i will post the dyno sheet tomorrow...thanks for everyones contribution and help.
i will tell you all how it goes once ive put this bigger actuator in...dissapointed in the hks actuator as its not holding that wastegate shut...
any advice or direction to a 19psi actuator would be great.
level of 40 knock is reasonable levels of detonation - check the tune or just make sure all is ok
see if backing out 1 or 2psi removes that level of knocking, if so it might need 1 or 2deg taken out on the map somehwere
keep an eye on it (covered in the PFC FAQ) at 60 the engine check light will flash
    • If the tyres were fitted when new, I wouldn't expect much over 5 years of use. Especially if the car lives outside full time.  If the tyres had been stored under ideal conditions and are being purchased new, I'd fit a set of already 5 year old tyres if I only expected to get 1 to 2 years of use out of them.  I've purchased many a set of new (but quite old) tyres from St George Tyres when I just needed some decent rear tyres to drift on.  Here is a pretty crazy example, can't say I've ever bought 11 year old tyres from them before though lol.  https://www.stgeorgetyres.com.au/momo-tyres-245-45-17-outrun-m3-official-product-by-momo-italy.html
    • Also, a tip for young players  Check the dates on new tyres before they fit them, I always ask this question at the tyre shop, as they have tried to put "new" tyres on one of my cars a few years ago, but the build date was about 3 years old
    • Yeah - 4 or 5 years is the limit for decent tyres. Pedestrian grade tyres with 400 TW ratings start out hard and don't start to suffer until they are somewhat older again. But the stickier decent stuff? Nup. My current ADO9s are < 2 yrs old, 17000km in, only have about the minimum 2mm of tread depth left, and they are.....not what they used to be. They are clearly much harder now than when new. Whether that is heat cycles (unlikely, for a road tyre), different compound between top and bottom of tread, or actually aging out (in less than 2 years!!!) is not really able to be discerned. But I'd credit actual aging as being at least part of the cause. I've got an old pair of ~50% worn AD08Rs in the shed that I really need to get rid of. They started feeling waaaay too hard to put back on the car after a couple of years sitting there.
    • Personally I wouldn't put tyres over 4 or 5 years old on any of my own cars. Once they go hard the grip characteristics completely change. As per most things it only matters in an accident and that's when you most want them to do their job!
    • I'm replacing the front tyres on the E39 tomorrow because one of them has a few gouges out of it. There is so much tread still on them but they're also 9 years old and the rubber is super hard.  This falls within the guidelines of 10 years old that I've read which surprises me given their condition.  I'm curious about whether you guys care about tyre age or just judge the tyre based on condition? How old would you consider too old?
