HKS 60mm Ext Temp gauge with wires, sensor, NEW, never install on a car..$ 230.
HKS 60mm Electrical boost gauge with wires, sensor, near new condition..$190
Apexi 60mm boost EL gauge + Greddy A-pillar pod , near new condition, $250
Border 60mm carbon / fireglass gauge holder, $200
Sydney buyer pick up prefered, Interstate buyer pay postage, direct deposit prefered. PM me..
Price updated..
Does the border gauge holder fits R33? I know they were made to suit dashboard for specific car make. And how do you mount them, any drilling required?
  Quote
Yes, it's designed for R33 GTST. and I used double side tape on my car without problem, just make sure you give the dash a good clean before you put it on...
Phillip - the A-pillar holder, is that for a 60mm gauge? if so, would you sell it seperately?
Second, the border gauge holder, is that for 60mm gauges too? (it looks like it).
Christian
  Quote
never mind, i re-read the post.. but would you sell seperately?
  Quote
Originally posted by tridentt150v
No PM received.........if u sent 1 2 me it didn't make it.
I pm'ed you with my number to ring me..if sell fall through, will let you know..
    • The more I think about it, the more I should probably go with a genuine Bride seat and rail set up. But damn the $$$ for a driver and passenger seat + rails!
    • From what I understand, stock internals should hold out for a while even if you run 500 at the crank, no? Especially if you don't run a modern turbo setup that reaches power and torque much earlier than the original twins. My engine isn't unopened either, it has N1 Pumps, head oil restrictor, new crank and cams, new piston rings, ARP head studs and Cometic headgasket along with 2860-5s. Considering everything is healthy this should run fine for a while I assume. Once my engine stops leaking shit everywhere, it'll be tuned to 370 crank first anyway, because I need to legalize the turbo setup. If I end up needing a new engine because my block actually has an issue, even though GTSboy was adamant that the whole porous block story is nonsense, before putting an engine in I'm probably gonna take care of the weakspots.
    • Hah, I have no issues with what you are doing whatsoever! You clearly know what you are getting yourself into. It's just funny reading things like this. "What's that noise?" "Oh, that's normal. That's just the engine not getting any oil. Nothing to worry about. It'll go away in a moment"
    • Yeah I'm keeping an eye on it and might take it out as a once off if this doesn't fully charge. I did some research that said it's normal in equalisation charging. Voltage I thought was 20+ (faulty battery in multimeter) but now its on 15.9v, the max it should go to is 16.2v as per the manual. I'll provide an update once hopefully it's actually fully charged and in float mode. Waiting for it to go to 16.2v and not higher and see what happens. What I suspect has happened is that even though it's not an old battery, I did leave the car turned off for almost 4 weeks at one point then left it off for another 2 weeks which might have erroded the battery and is taking a long time to do this equlisation charge.
    • I wouldn't be using the seats a lot since it's on Historic rego and will not be driven a lot, however I also don't want to fork out 3k for something that won't last. Havent looked at BRZ seats, aiming for something of the same era I did speak to him on the phone once, and I do see your point haha. How many kms do you think you drove before they started wearing out? Just had a look at yours, certainly looking for a reclinable version. The Brides don't look too bad! I would still like to sit in one just to make sure it's what I'm after.    Thanks for the replies fellas.
