Item is brand new - Retails at $139 for individual item- Im asking $100. Brought for an old project - have moved on. Purchased as a package with other rear end suspension components from nissansilvia.com. Bar fits Silvia 180sx 200sx S13 S14 S15 Skyline R32 R33 R34 Cefiro A31 300ZX Z32. Threaded left hand and right hand in middle for adjustability..........................The Front Lower Arm Bar adds more front end chassis rigidity when cornering/drifting. Helps keep the front suspension geometry constant - essentially a strut brace for your suspension. *Made from a 4140 Cro-molly steel, the D-Project Front Lower Arm Bar Brace will increase front chassis rigidity and front tyre grip! *Benefits: Rigid front chassis = More Front Grip= More Angle = BETTER SLIDES with more control! *Quality construction - Centre Turn Buckle Adjustment - enables you to pre-load the tension rod housings for high corner loads. Cheers.........Payment on pickup is fine or can post at your cost...............Item located North Eastern Adelaide.
Edited by tiels32
