Was kinda hoping they would do redline as well.
Does anyone wanna add some info on australian guidelines for labeling on oil? e.g. why motul will say 100% synthetic +ester and why do most of the rest use 'full synthetic'
  • Replies 55
Posted Images
I thought that the Castrol Edge is a hydrocrack mineral oil type synthetic, making it a Group 3 and the Motul 300v and Mobil 1 are a Group V poly ester man made oil?
The oil thread has more info than you'd ever care about. All I know is that my car seemed to run better on Motul 8100 Xcess 5w40 which is a Group 4 oil than the Castrol EDGE 5w30.
The oil thread is very good, has a great summary of oil classes.
Im a big 8100 xcess fan as i used to use 300v but at 150bux a change every 1000kms was a lil overkill.
you don't need to change every 1000km's, especially with such a good oil like 300V - 10K is fine, or 6 months, whichever comes first.
Castrol EDGE seems to be a Group IV, and i guess a pretty cheap group iv at that (i swear when it first came out it was a III) but it seems there is a 'Sports' version that may be a Group III (gotta do some more digging)
Mobil 1 is a funny one, as with a few oil brands it depends on what weight/viscosity you get. Ie, a 0w30 could be a Group IV+ but the same named oil in 10w40 could be Group III. Makes things confusing and i know Mobil 1 has copped some heat regarding some of their range.
Mobil and Castrol are generally a little cagey about what base stock everything else, but you're always well off to do an UOA anyway.
If you really want the absolute best, just buy Redline.
lil bit off the subject
but ive seen how some people have got lil cartoons at the bottom of there posts
a bloke on here has one of a green s13
what are they and how do u make them?
thanks guys
http://www.pixelcars.com/index.php
Pixel Cars.
:P
Or just sit in front of Microsoft Paint for hours / days doing it yourself... LOL!
in my experience the results of the oils can vary depending on the engine types, considerably. Some engines just like some oils more.
I run Castrol Edge in my skyline on the advice of Guilt Toy
I run Penrite HPR40 in my sigma as its proven to perform in the 4g54
I'd be keen to see a test run by Top Gear or something testing oils across the same car completely impartially. I once read a magazine article ages back that compared oils by subjecting it to a friction test on a peice of steel round bar against a metal plate. The resulting wear or lack of after X runs showed the best results. Royal Purple, motul and penrite all did very well. Edge wasnt around then...
An oil isnt proven by a poofteenth of a kW on a dyno, its proven by wear, temperatures and the way it looks at each oil change.
exactly!
what kind of retards base their choice of oil an a few kws difference on a dyno. a suss dyno at that.
those tests fail in every department.
Yes all that magazinbe article showed was that it is pointless testing an oil the same way you would test grease.
An oil will generally allow the motor to develop more horepower if it has a lower viscosity & more friction modifiers in it.
With regard to how it looks when it is in your sump - usually the blacker it is the better it works to absorb the crap that would otherwise be left in your motor. Ofcourse if it is the oil itself doing this you are in a bit of trouble....
exactly!
Have to agree about not choosing an oil based on a few kW... Personally, I'm a bit more interested in the properties of the oil as a whole. The whole test seems a bit strange, nice work on spotting the fan distance pics. Some unusual variation there...
Won't be switching any time soon, sticking with Motul in the R34.
An easy way to tell if it is the crap from the engine or the oil itself is to take note when draining the hot oil during a change.
It should come out black initially, but the oil should not be black when it gets to a light drizzle (the crud comes out mostly early on when you drain the oil).
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
