Ok then where do i start. I've got an R33Gts-t. Its a standard engine but with a race head gasket. Its got a greddy inlet plenum with 740 injectors and a turbometics A.65 series turbo and a full 4" straight through exhaust. I've got a race rad and a greddy oil cooler and filter relocator. Its putting out 549bhp on the top map. Heres the problem, im having really bad heat soak/transfer to everything under the bonnet. Im after some advice and ideas as to how i can reduce the heat problem. Its not overheating or anything but everything is really hot. I've wrapped the manifold and got a heat shield on the turbo. Im considering putting an water/oil cooler on the gearbox to help there.
https://www.sau.com.au/forums/topic/278215-heat-soak/
lol @ 409KW on a stock RB25!
But even so... its an engine. It gets hot. Unless its sapping the performance its not actually bad to have a hot engine...
If your really worried raise the rear of the bonnet, or get a vented bonnet.
Edited by gotRICE?
https://www.sau.com.au/forums/topic/278215-heat-soak/#findComment-4702003
... raise the rear of the bonnet, ...
How can that help? It's a high air pressure region at the base of the windscreen. How else do you think you get air in through the heater vents. Or how those "reverse scoop" bonnets worked on old-school Falcons and Commodores? All you will do is push air into the engine bay. Then you will have overheating problems because there is no pressure differential to allow cool air to come in through the radiator.
Back to the original problem - it's an engine making lots of power, of course it's going to generate some heat.
https://www.sau.com.au/forums/topic/278215-heat-soak/#findComment-4702024
thanks for your replys guys. I have a carbon triple vent bonnet on it already. I've been considering an intercooler mister to try and cool the inlet charge a little and maybe put a mister on the oil cooler while im at it. I've also looked into fitting an electric water pump which would keep the water circulating after the engine is switched off for a while until the engine temperature has dropped to a level im happy with. What about venting air from vents at the bottom of my do-luck from bumper up into the engine bay at the inlet plenum and manifold to try and keep them cooler when driving?
Regards, Thwish
https://www.sau.com.au/forums/topic/278215-heat-soak/#findComment-4702206
Is it a track car or road?
Do you always get heat soak? or just after a short drive?
raising the rear of the bonnet will kind of help, ONLY if youre not racing that is.. ie on the streets.
Why dont you take out the AC? Or perhaps run a few elec fans between the fmic and the radiator?
The other question, is it a high mount or low mount turbo?
https://www.sau.com.au/forums/topic/278215-heat-soak/#findComment-4702229
If its a stainless exhaust manifold, good luck keeping the heat out.
Gauge the engine temp via the ecu, see what it is reading, watch as it heats up, fans come on and if temp movement decreases.
Another thing, is it too lean???? AFR?
https://www.sau.com.au/forums/topic/278215-heat-soak/#findComment-4703295
Again thanks for all your comments guys. Ok then, i'll try and answer as many questions as i can.
1. Its used 99% on the road but gets really used lol.
2. Its running on a Greddy/Trust Topmount stainless steel manifold.
3. Dont know the actual temps as i dont have any sensors measuring it.
4. I just go by how hand hot the actual inlet plenum and intercooling piping gets.
5. The temp gauge in the dash doesn't show it going over half way so its not overheating as such but just want to get the overall temp down as it cant be doing much good for power and engine wear.
Thanks for all your input, it is much appreciated. Thwish
https://www.sau.com.au/forums/topic/278215-heat-soak/#findComment-4703399
Point 3 needs to be covered. How do you know it's hotter than NORMAL, unless you know that actual temperature.
The fact is, even a standard RB engine is usually too hot to touch anywhere once it's been for a 10 minute drive. I'm guessing yours is the same, but if you can take a temp reading with a laser pointer or temp gauge on a multimeter, then I will be able to tell you if it's normal or not.
https://www.sau.com.au/forums/topic/278215-heat-soak/#findComment-4703418
why not put a temp sensor in the intercooler piping just after the turbo but before the intercooler and another one after the intercooler just before the plenum to see what the actual intake temp is and if it is affecting how the intercooler is doing it's job. if you really wanted you could have 2 on the cold side of the cooler, 1 just after the intercooler and one in the plenum to see if it is having any effect. but i would doubt it is having much of an effect as the air is passing pretty quick through the plenum and piping, but if it is causing the intercooler to heat up dramatically then you will be losing power.
https://www.sau.com.au/forums/topic/278215-heat-soak/#findComment-4705135
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
