  • Replies 65
Hey Ryan the diff is pretty much brand new i bought it from a friend but never finished my car to use it, its done about ~5000k's it comes complete in housing with half shafts, it needs oil though as i drained the oil and put on a brand new nissan gasket on the rear cover. As for the GB mount id rather not separate it from the engine mounts at the present time.
Hey mate can you please PM me info on the TT lsd and the engine and gear box mounts please.
Cheers,
Ryan
http://www.autometer.com/cat_accessoriesdetail.aspx?vid=159 its this one here and shipping would be $10
pics of the shiftlight please
how much posted to 2500?
Edited by /2on
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
