thanks dude! ive already PMd him
if anyone else wants it, im now using my jedi mind trick to make you forget about it
'you do not want that throttle body, he is selling it to iain'
so yeah, looks like its mine :mellow:
  • Replies 46
nice work dude
i pulled my PCV valve out yesterday to check it. it works fine and was a little oily (to be expected) and i was going to clean it but realised i parked my car infront of the shelf that its stored on and couldnt get to it lol
also, learnt the vq35 throttle bodies are the same size as ours, and its quite large already..........
Dammnnn, Well at least we know who has a spare one for sale if anyone stuffs theirs up.
  • 8 years later...
Reviving a zombie thread from the glory days - and registered - just to say WOOT! Thanks guys, prolly saved me a packet 'troubleshooting-by-replacement'!
Anyhow, just to confirm blocking the PCV tube downstream of the TB dropped a high, surging idle on a 2008 Nissan 350z VQ35HR (that had just stupidly had its TB's cleaned) down to around 850rpm - and allowed an idle relearn to run & stick. It now sits on 650rpm and ~15deg BTDC. Pretty much perfect!
After reading soooo maaaany threads on this topic - generally without resolution (other than TB/ECU replacement), I figured it might be worth posting my thanks and confirmed resolution and hopefully gaining you a few Google search ranking levels in the process ;-)
Cheers,
Guv
  • 2 years later...
Hi - to also add to an old thread.
I've been having the same issues and unable to complete the air idle volume learning to happen and drop my revs. I read heaps of stuff from G37, 350Z, and even pathfinders, that there is a common issue with unplugging the throttle bodies and not able to complete the relearn (especially with the VQ35HR engine)
I saw a post on 350z forum and gave it a try - I unplugged both throttle bodies and left them a few moments, before plugging back in. It worked! - it must have put the ECU out of its funk and allowed the learning procedure to work!
Now lets hope it stays that way!
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
