Is there any point to putting some sort of ignition cut on an engine, so when you crank a cold engine it doesnt fire.
Idea being to get some oil circulating thru the engine before you fire it. Or is there really nothing to be gained from cranking the engine half a dozen times before firing it.
https://www.sau.com.au/forums/topic/27831-engines-lubricationoil-system/
Hi
This isn’t really my area, so please don’t take my word as gospel, buy surly if you crank the engine over you are still going to cause a similar amount of damage as you would if it were to fire up cold.
I too have been considering a system to give better protection for cold stars and recall that in the US in the 70's (Dodge Darts, 426 Hemi etc) they had a pressure loaded oil cylinder that they released prior to starting. (I think it filled slowly during normal operation via a one way valve, which can be released/bypassed prior to starting) The idea was that it primed all of the oil system.
Alternatively an electric pump that taps into your existing system could be used to prime the system.
I don’t know if you can buy such parts, or if in the long run it makes much difference, but it would give me piece of mind.
Yeh i have read how some drag cars have oil primer pumps.
A couple pf the reasons i thought about it is that having a high mount plain bearing turbo, it would ensure the bearings have some oil flow before spinning.
Also the fact that there is no spark would mean there is no actual loads on thing like bearings as there is no compression/ ignition/ expansion of fuel mixture.
So whilst the engine is turning over on the starter motor there is much reduced load as there is no bang sending the piston/rod down the bore and crank swinging.
Finally rigging up such a system could be as cheap as $5, by placing a toggle switch on the earth of the igniter??? or something similar (Would really have to look at a wiring diagram)
So provided it isnt doing any harm (battery life perhaps?) then it may only help, and also perhaps stop a thief who doesnt realise why the car wont turn over, and leaves quits once the battery is dead.
You shouldnt need an oil primer in most cases. You're pretty much wasting your time. Get a quality oil filter with a good anti-drainback valve and some 5W or 0W rated oil and you've got all the cold start protection you need.
If anything, a slow crank will not sufficiently oil up the system over a few seconds. It might take 10-20 seconds before its fully primed at cranking speed. And your bearings are still 1/2 dry during this period. You might aswell just start it and the oil pressure will be up in no time...
Just take it easy when the engine is cold. That is the key...
don't bother with special measures.
if you cut ignition or fuel, you're still compressing air into the engine so there is some load. the engine won't fire but there's still some load. the starter motor is also very high torque and that loads the engine too.
You'd have to remove all the plugs and turn the engine over by hand many times until oil came up to truly have no load. I wouldn't worry about the turbo either, they don't spin fast at idle and again there's not much load on them.
Genuine filter with anti-drainback valve, 5W oil and let it idle for 30 seconds when you start it, then drive it off gently until it is warm. That's all you need, motors are designed to be cold started (not excessively but a reasonable usage) and with synthetic oil you won't get nearly as much drain off components as mineral oil (not that anyone w/ turbo cars uses mineral but compared to normal engines out there - my charade always used mineral and revved its tits off after 140,000km of hard use!)
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
